  • 4 weeks later...
R32 with RB25DET
ebay 3076 .73a/r internal gate
Stock mani
3" exhaust
Gutted cat
3" intake pipe
Plazmaman fmic
Forward facing plenum
Top feed rail
1000cc injectors
90mm TB
Nistune
E85
Cousins car tuned at unigroup.
Rebuilt stock Rb25DET
Kinugawa T67 25G 8cm, Turbosmart 45 gate
600x300x100mm cooler (cant remember brand) with custom piping.
740cc nismo injectors, walbro 400 fuel pump
Apexi power fc
5zigen exhaust, custom dump
Stock intake/exhaust manifolds
Its insanely responsive as you can see.. 177-179rwkw by 4k.. then around 220rwkw an extra 500rpm later.. pulls like a freight train!
Update for my setup....
Same mods:
Motor was rebuilt around 15k km ago with
arp rod bolts/head studs
acl bearings
treated and prepped oem rods and crank
Ross forged Pistons
1.2mm cometic gasket
Tomei poncams
Brand new oem lifters
performance springs
Apexi power fc
turbosmart eboost2
R32 gtr itb's
4 inch hard intake pipe with apexi pod & z32 afm
Cusco plumb back air oil separator
splitfires
Quest 125A alternator
walbro 460 pump
HKS 2835 Pro S 56T 0.87ar
Turbosmart internal gate actuator
hpi turbo manifold, exhaust special hks 2835 pro s dump pipe into a genuine hpi split front pipe into straight through 3 inch exhaust with no mufflers or cat etc......
Runs United E85
24psi
Some small mods to my actuator yielded better spool, response and held boost stronger resulting in a 15hp better peak and 100hp gain at 3700rpm
It's a blistering setup and an almost unbeatable street car being a light weight and highly tuned semi stripped s13 chassis and even my 315/30 nitto Nt01's can't get the power down anymore haha
Responsive!!!!
  • Like 3
Unopened R33 Rb25DET
HyperGears 21U G3 high flow internally gated
600x300x76mm cooler kit.
1000cc ID injectors, walbro 470 fuel pump
Apexi power fc
3 inches Turboback exhaust
20psi @ 3500RPM, 291rwkws E85 fuel
S1 rb25, Wiseco pistons, BC rods, Cosworth metal HG, all ARP hardware, Greddy intake
Bullseye power s259 turbo t3 .76 twinscroll, Precision 44mm gate on a trust style manifold
SARD 800CC, TOMEI fpr, Aeromotive stealth pump
JUN crank collar, N1 oil pump, tomei oil restrictors
521whp @ 29psi on a dynapack
 Base tune only, missing poncams and +1000 rpm on the clock (redline at 7000)
Will hopefully post the next results before the end of the summer :224_monkey:
  • Like 1
  • 4 weeks later...
1996 Nissan Skyline R33 Gts25t SII
RB25det fully rebuilt with Metal Head Gasket etc.
Kelford Cams.
RIPS Front Facing Plenum
RIPS Sump.
Tial 38mm External Wastegate
HKS EVC-S Boost Controller
Masterpower Custom Turbo. Unsure of Specs. Have been told it is a GT37.
Nismo Fuel Pump.
Front Mount Intercooler.
Apexi Power Intake
440cc Injectors from WRX Sti
Sard Fuel Pressure Regulator
BP Ultimate 98 Fuel.
Oil Cooler and Greedy Oil Filter Relocation Block with Thermostat.
Extreme Clutch.
Braided Lines through out
Apexi Power FC
300zx AFM
  • Like 1
95 r33 skyline Unopened rb25det
Stock Injectors, maf, fuel pump, airbox
Power fc
Blitz return flow
Splitfires
Hypergear 21u high flowed g2 profile at 18psi
Avcr
Maf and Injectors maxing out. This seem alright to you guys?  or could I squeeze some more without upgrading Injectors, maf, etc
  • 5 weeks later...
R33 GTSt S2
Tomei headgasket
ARP studs
Tomei 256 poncams
Performance Valvesprings
Gt3076r-wg
1000cc injectors
Powered by a Link G4+ plugin
Needs crank trigger kit
496whp on E85 20psi
460whp on P98 18psi
  • Like 1
  • 1 month later...
R33 gtst s2
Rb25det
Just jap exhaust cam gear retarded 2•
Small hi flow turbo unknown possibly mtq with a r32 turbine housing
Silcone intake z32 afm k&n panel std airbox
R32 actuator
Eboost street 16psi dropping to 14psi
S15 480cc inj
Blitz return flow fmic
Hks dual 2 5inch catback and 3inch jjr dump and hi flow cat
Dw300lph fuel pump re earthed
Z32 ecu nistune tune by evan [mention=93559]unigroup[/mention] engineering
209rwkw on 16psi tappering of to 14psi
Replaced the actuator with a hypergear 1bar item as boost controller was on 100% duty now on 18psi tappering to 16psi 80% duty comes on boost like standard but dont have to worry about the ceramic turbine coming off
A31 Cefiro
Haltech Platinum plug and play R32/R33
RB25 NEO forged internals
Arp head studs, mls head gasket
springs/retainers, 260 type B Tomei cams
Gtx3076r 1.06A/R twin scroll
6boost T3 exhaust manifold
Custom 3" exhaust turbo back
50mm Turbosmart gate plumed back
Greddy plenum, 1250cc Bosch injectors,
Turbosmart FPR 1200 fuel reg
Walbro 460Lph fuel pump
Running Flex tune E85
Made:
441hp on 21psi (BP98)
522hp on 24psi (E85)
530hp on 30psi (E85)
Loosing boost at high boost levels, suspecting a leak so there is more left in the setup, looking at getting a Plazmaman Intercooler and getting a bunch of stuff rapped up in order to try lower the IAT, climbing towards 50 degrees Celsius at the moment. But the car is very fun to drive, going to E85 is a huge difference, for anyone thinking of converting... Do it its totally worth the money spent on parts. I think the rpm on the dyno might have been a bit off on the day because last tune one the same dyno i was hitting full boost at 4200 rpm. The car feels very responsive
Edited by Chuki
On 8/10/2007 at 9:56 AM, mikel said:
Update
just had a retune 9 Aug 07
no mods from below except 98 RON BP ultimate
more timing added with the boost sneaking to 16PSI then dropping back to 13.5 PSI
235 rwKW :nyaanyaa:
cheers
Mike
I wish that I'd posted the dyno graphs back in 2007, as I can't find them now, but I suspect that the 235 rwKW back in 2007 was likely the dyno reading a little high, given it had standard injectors and fuel pump at the time...
Fast forward to 2017, the engine is now a NEO top and bottom with "unknown" aftermarket cams, R33 sidefeed 555 injectors, Walbro 155 LPH fuel pump, turbotech bleed valve, PowerFC, steel suction pipe, HKS 25/30 turbo.
234 rwKW - tuned by Anthony (Guilt Toy) at EFI Performance Tuning in Newcastle https://www.facebook.com/tunedbyanthony/
cheers,
Mike
  • 1 month later...
C34 Stagea S2
Unopened RB25DET Neo
Stock Intake and exhaust manifold (modified with 12mm T3-T4 spacer)
Borg Warner Airwerks S257SX-E 0.83 T4 split pulse
Tial MVR 44mm external gate on rear housing
3" Turbo back exhaust, Highflow cat, HKS Super drager muffler
Nistune with flex sensor and feature pack 2
Walbro 485 fuel pump
Bosch R8 coilpacks
Greddy Profec B spec II EBC
Rev limit dropped to 6800
Has a boost leak, boost drop at about 5500rpm to 17 psi
Made 266rwkw on 98 @ 18psi
Made 302rwkw on e85 @ 19ish psi
  • 2 months later...
R34 GTT sedan manual:
  • Hypergear ATR43-SS2 internally gated on stock manifold
  • Rebuilt actuator arm with preload
  • Stock airbox and snorkel
  • Ryco panel filter
  • New Z32 AFM and plug
  • Scotty's 3" intake pipe
  • Trust turn flow intercooler
  • Blitz Dual SBC Spec R EBC (dual solenoid)
  • Splitfire coil packs
  • NGK BCPR6ES-11 spark plugs regapped
  • Deatchwerks 800cc injectors
  • Walbro F90000274 450L/hr fuel pump E85 safe
  • Fuel pump direct feed rewire from the battery, 8-gauge wire
  • Fuel tank lid rewire with bulk head terminals (Feb 2018)
  • Magnafuel fuel regulator
  • JJR 3" bellmouth front/dump (modified)
  • Venom 5" body high flow cat
  • PEX/Berklee mid muffler
  • 3" HKS Super Drager rear muffler
  • Full manual conversion using R34 gearbox and parts
  • Nistune
Result: 318rwkw @ ~20psi, United E85
This confirms that the:
  • Stock airbox
  • Basic panel filter
all go past 300 rwkw :)
  • Like 4
  • 1 month later...
R33 gtst s2 manual:
Gt3582r .82 rear housing on a custom manifold externally gated and plumbed back
Forged pistons, rods, arp main and head studs with 1.5mm metal headgasket
Stock head fresh refurbish with tomei drop in 256 cams
460lph intank pump direct relay from battery with bosch 1000cc injectors
4 inch from turbo to 3.5 inch through high flow cat and 4 inch tip
440.2 whp at 20psi with united e85
Needs alot more mid range not sure what is really holding it back my guess being a shit manifold or old spec turbo. Keen to hear some thoughts20180321_183015.jpg
11 hours ago, pogman said:
R33 gtst s2 manual:
Probably cause you put a 1.5mm HG on it lol. Wind the boost up. I'd put a 1.2 back in and wind the boost up for sure with a built bottom end.
I'm running an old spec 3076 on a CRG mani external gate with fresh head and tomei poncams, stock S2 bottom end, only a 3" custom dump and exhaust and made 500.9whp on 20psi E85 through the manual, now 444.9whp through the glide.
is your VCT working? I would check that.. also see if your timing belt is on properly and both cam gears are aligned.
Run more boost too, don't be a pussy :)
  • Like 1
The head gasket was recommended by the mechanic when doing a freshen up on the engine and as a newbie i just went with it, whats the advantage of thr 1.2mm hg over the 1.5mm? Will definitely crank the boost up once i get used to this power abit more but would like a surge set up first.
Run more boost too, don't be a pussy [emoji4]
I will definitely check those when i next get the chance and may potentially take it to a different shop to see what they can get out of it. More boost is definitely on the card soon
