R34 GTT Rb25det Neo standard engine
ARP head studs
HyperGear ATR43SS-2 ball bearing turbocharger
6 boost high mount exhaust manifold
50mm external gate
4 inches intake pipe
600x300x71mm front mount intercooler
3.5 inches turbo back exhaust
1000cc ID injectors
Haltec ECU
Tuned by Chequered tuning Melbourne
Final result of 355rwkws on pump 98 fuel / Ron 93 at 20psi, hitting 220rwkws @ 4000RPM.
  • Like 3
  • 1 month later...
R33 Rb25det unopened engine
Greddy intake manifold
82mm Bosch DBW
@hypergear ATR43SS-2 ball Bering turbo
Factory exhaust manifold
45mm external gate welded to turbo housing
3 inches intake pipe
Greddy front mount intercooler with 3” piping
3.5” exhaust (3” from turbo, stepped up to 3.5” at wastegate merge)
1000cc Xspurt injectors
Haltech Elite 2500 ECU
Tuned by Revolution Engine Services (NZ)
Final result of 314kw (at the hubs) on pump 98 fuel at 19psi, hitting full boost by 4000RPM.
  • Like 6
  • 3 weeks later...
R33 GTST 4 door
Rb25det Neo engine
Forged pistons and con-rod
Ross performance trigger kit
1650cc Bosch fuel injectors
Two 460L fuel pumps
Adaptronic plugin ECU
Upgraded Valve springs
Hypergear ATR43SS-3 Turbocharger
6 boost high mount TS exhaust manifold
Twin turbosmart 50mm external gates
Tuned at Chequeredtuning Victoria
Car made a final result of 482rwkws @ 24psi. Hitting 280rwkws @ 4000RPM with wide spread of power band and plenty of area under curve.
  • Like 3
  • 5 weeks later...
324.51RWKW, new turbo and other bits installed by the guys at Jaustech in SA.
Tuned by Pete from Nistune on 98 fuel. Crazy good tune.
Running just under 18 PSI and have full boost by 3300rpm, which was an improvement over my previous setup only hitting 18 PSI at 3800 RPM. Huge different in driving feel and power delivery. Could go higher boost, but don't want to ;)
Overall, very quiet still, but pulls very hard and to hit this power with under 18 PSI, with boost coming on that early is nuts IMO.
The EWG port was added onto the hot side of the turbo, the stock manifold has been untouched. Still a low-mount.
Specs:
  • R34: RB25DET NEO
  • Pulsar G30-660 turbo
  • Turbosmart EWG and a 4 port solenoid to keep the gate shut and maintain boost.
  • Tomei Poncams Type B 260deg
  • APEXi Pod Filter
  • Nistune ECU
  • ARP head studs
  • R35 GTR Injectors
  • Walbro 255LPH Fuel Pump
  • GReddy Profec B-Spec II EBC
  • Return flow FMIC (unsure of brand, I didn't do this one)
  • Custom 3" Dump pipe with EWG plumb back. No screamer pipes here.
  • High flow catalytic converter
  • 3" Fujitsubo Giken FGK Exhaust.
  • Koyorad Radiator
Absolute killer setup!
Edited by Bman1296
  • Like 8
R33 GTST forged rb25et engine
Standard head and cams
ARP head studs
Supertech valve springs kit
50mm external gate
1000cc ID injectors
Link ECU
Final result of 372rwkws at 25psi Pump 98 fuel.
Edited by hypergear
  • Like 2
  • 7 months later...
-ENGINE: RB25Det Neo
-CAR MAKE: Nissan
-MODEL: R33 GTST
-ENGINE BUILD SPECS: Forged bottom end with upgrade valve springs.
-INJECTORS: Bosch 1600cc injectors with twin 460L Pump
-TURBO: HyperGear ATR43SS3ProR in T3 TS .82 rear housing
-CAMS: Stock rb25det
-FUEL TYPE: E85 fuel
-AUTO/MANUAL: PPG 6 Speed sequential
-Diff: Stock
-TORQUE: 755Mn
-HUB or CHASSIS DYNO: Hub dyno
-POWER OUTPUT:
Green ATR43SS3ProR 512rwkws @ 27psi
Vs Purple TD06SL2-25G 437rwkws @ 27psi (Before turbo upgrade)
424921853_903140998480628_8249758684058492188_n.thumb.jpg.16cc31944e7ac2cec67a2da958dfd09d.jpg
424867420_903140968480631_1710317124541873600_n.thumb.jpg.2c1121488c59239c421993d782feacbe.jpg
424974671_903142871813774_33584613756481776_n.thumb.jpg.5edf278056e470573db4dd8b0ed12496.jpg
  • 2 months later...
-CAR MAKE: Nissan
-MODEL: R34 GTT
-ENGINE BUILD SPECS: Stock bottom end, kelford 264/272 cams, valve springs, ARP head studs, Commetic Head gasket
-INJECTORS: Bosch 1600cc injectors with single 525L Pump
-TURBO: Garrett g30-900 .82 rear housing
-AUTO/MANUAL: Manual
-Diff: 2 way
-TORQUE: 660NM
-HUB or CHASSIS DYNO: Roller dyno
-POWER OUTPUT:
615hp on 26psi
dialed back to 595 on 24psi
460hp on 16psi
  • Like 5
  • 4 weeks later...
2.8L Stroked S1 RB25
Fully built block (Spool&CP) and head (Ferrea & Kelford 272's). Hydro lifters.
Precision 6466 Gen2 1.00 T4 Divided. 2x 40mm Turbosmart open dump gates.
DW 1200cc injectors
2x AEM 320LPH Pumps
Haltech Elite 2500, IC7, WB1, TC8, Etc.
4" Downpipe, 3.5" Catback.
94AKI (101.5ron) Pump gas + WMI (2x 1000cc nozzles)
463rwkws @ 27psi on a mustang roller dyno.
  • Like 1
  • 1 month later...
Stock rb25det
Td0620g bolt on turbo
555cc deutchwerks side feed injectors
Return flow front mount intercooler
Walbro 500hp intank fuel pump
Turbo smart rising rate fuel pressure regulator
Turbo smart blow off valve
300zx ecu with nistune
300zx airflow meter
434hp atw on hub dyno
DW 1200cc injectors
2x AEM 320LPH Pumps
After a quick revisit, I'm now at 478rwkws @ 27psi on a mustang roller dyno.
  • Like 2
  • 1 month later...
  • 2 months later...
C34 Stagea RS4S
Standard RB25DET Neo with ARP Headstuds and MLSR Gasket.
Bosch 1000cc injectors
Walbro 460
Standard neo inlet plenum w/rb25 s2 throttle body
6 Boost Low Mount Manifold
Turbosmart Gen V 45mm wastegate (recirculated)
Pulsar g30-770 (0.72 rear housing)
3.5"intake pipe to clear mounts, 3.5" dump to 3" exhaust
Link G4X Ecu
380 hp on 98 octane, 478 HP on e85 (mainline hub dyno)
Video of Earlier Run
Final Dyno Sheet:
Edited by Yeomo
  • Like 2
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
