R33 S1 Auto RB25DET (unopened)
OP6 Hypergear Highflow
3" TBE with High Flow Cat
Five-O 750cc Injectors
DeatchWerks DW200 Fuel Pump
Adaptronic E420D
Craigs Auto Stage 3 Shift Kit
United 100
Tuned by DVS JEZ
  • Like 1
'97 S2 R33 GTS-T
Only mods:
BLITZ return flow FMIC.
HKS 3" 'Super Dragger' cat back (stock cat + stock dump pipe still fitted).
Eboost Street 40
Since the attached dyno run ive added;
MINES tuned / mapped ECU
3" JJR bellmouth dump pipe
Not sure if the power figures are on-par with whats considered average / good / bad for whats been done ?
  • Like 1
R34 GTT sedan manual:
  • Hypergear ATR43-SS2 internally gated on stock manifold
  • Rebuilt actuator arm (~3mm preload)
  • Stock airbox and snorkel
  • K&N panel filter
  • Z32 AFM
  • Scotty's 3" intake pipe
  • Trust turn flow intercooler
  • Blitz Dual SBC Spec R EBC (dual solenoid)
  • Yellow Jacket coil packs
  • NGK BKR7EIX spark plugs regapped
  • Deatchwerks 800cc injectors
  • Walbro 255 LPH fuel pump
  • JJR 3" bellmouth front/dump (modified)
  • Venom 5" body high flow cat
  • PEX/Berklee mid muffler
  • 3" HKS Super Drager rear muffler
  • Full manual conversion using R34 gearbox and parts
  • Nistune
Result: 275rwkw @ ~20psi, BP 98 Octane (red line)
Without airbox lid, snorkel and filter: 285rwkw (top blue line)
  • 3 weeks later...
Running daily 286rwkw@19psi for 1.5yrs now no problems.
R33 Gtst S2
Hypergear Rebuild .82
3"turbo back
555cc drop ins
bosch 040
Greddy Return Flow
Nistune
Airpod + Enclosure
Unopened Engine
Engine bay is looks Completely Stock
  • Like 1
2000 R34 GT-T
209 rwkw stock turbo
-Engine management - Apexi safc neo (piggy back)
-Boost ran 12.5 psi
-Fuel used (pump or special) 100 octane
-significant engine mods (eg cams) n/a
high flow 100 cell cat, 3"front pipe, stock dump pipe, HKS silent back cat back.
​Apexi super flow pod, heat shield to stop heat soak
Go Fast Bits EBC
​very smooth host curve.
  • Like 1
  • 3 weeks later...
ECR33 1998
RB25DET
Stock block, pistons, crankshaft, etc.
Cylinder head with porting, Tomei Poncam 256/8,5, Stock Gasket.
t3t4 Chiniese turbocharger a/r60
Denso 550cc injectors
Walbro 255 l/h fuelpump
Custom intake & exhaust
MAF Z32
ECU Apexi Power FC with boostkit
AEM Watermethanol with Russian Vodka
BP 98 Fuel
432 hp & 480Nm at 1,05 bar without vodka.
431 hp & 520Nm at 1,35 bar with vodka.
427 hp & 550Nm at 1,54 bar with vodka.
Edited by RB_Brother
1996 R33 Gtst S2
  • Hypergear Atr43g3 turbo running 19psi - braided lines etc
  • Custom 3 inch metal intake
  • genuine z32 afm
  • 740cc nismo injectors
  • cheap pod filter
  • Hdi intercooler
  • jjr 3 inch dump pipe -- highflowed cat -- 3.5 or 4 inch catback with a 4.5 * tip -- had to modify it to make it fit
  • Walbro gss342 fuel pump
  • Npc Organic clutch
  • Greddy profec b spec 2 boost controller
  • Unopened
  • Tuned to p100 united fuel
  • stock coilpacks
  • Apexi Power FC
  • There's other small stuff and may have forgotten
May have a small boost leak, made 365hp at the rear wheels
  • 3 weeks later...
Rb25 s1 motor in r32 shell
Gt3076 .73 rear housing
Ext gate of rear housing
Standard ex and intake manifold
Un opened motor
Split fire coilpacks
Xspurt 1400cc injectors with top feed rail
3 litre surge and x2 external pumps
Caltex eflex fuel
Standard airbox
3inch exhaust
Adaptronic ecu
Around 20 psi
326kw at the wheels daily driven
Tuned by guiltoy
  • 3 weeks later...
Can I get some opinion on what u guys think of my dyno result I think it's a bit lazy but professional opinion would be great.
Fresh rebuilt rb25det s1
Td06-25g kinugawa 18psi on
Stock low mount manifold
254 cams
1000cc
460lph walbro pump
E85
Ffp
Splitfires
Hypergear OP6 highflow, tuned by Toshi
RB25 stock internals, 97 R33 gtst, 20psi, 276rwkw
Supporting mods below:
z32 AFM
Scotty's metal intake
return flow FMIC
PFC with boost controller kit
Bosch EV14 injectors
splitfire coilpacks
turboback exhaust incl split dump pipe and highflow cat
Edited by chiksluvit
  • Like 3
1993 R33 Series 1 RB25det unopened after 304,000kms.
Apexi Power FC
Z32 MAF
Chinese blitz copy return flow FMIC
Hypergear ATR43SS2 0.82 rear
Turbosmart External wastegate 40mm Compgate
3" exhaust from turbo 1 x coby 3" resonator 1 x RPS 3" muffler both straigt through
850cc remanufactured injectors (ebay)
Deatschwerks Dw300 intake pump
284Kw @ 17psi
  • Like 3
Spec list as follows:
1994 S1 R33
~165,000 kms, unopened engine
Nistune ECU
GTX3067 w/ 0.82 A/R Garrett internal gate housing
[Note: yes the smaller 3067, not typo of 3076]
Stock manifolds
Pod filter - Alloy pipe intake
Z32 AFM
Splitfire coilpacks
Blitz SE return flow FMIC
Greddy Profec OLED boost controller
Nismo 740cc injectors
Walbro 465 pump
3" Custom stainless exhaust turbo back w/ high flow cat.
Changed turbine housing to 0.63A/R internal gate. Blue line is with 0.82, and red 0.63.
R34 ,Hypergear High flowed Turbo with HP Actuator
750 cc Injectors
Z32 Air flow meter
Apexi Power Fc with HC
ACS Carbon Comp Clutch
Apexi FMIC
HKS Exhaust
E85 Safe Tune 306kw or 410hp @19psi
Very responsive ,does everything right !!
Walbro 460L
Work done by EFI Performance Gold Coast !!!! :cheers:
  • Like 1
1999 R34 GTT S2
Stock ECU
Stock AFM
Greddy Copy FMIC
Stock Turbo
HKS Dual Stage Boost Controller
3" Exhaust Stainless
Stock Injectors
Stock Fuel Pump
186kw @ 12psi Baseline Run with OP6 Plastic Wheel Turbo Dropping off to 9psi.
  • 4 weeks later...
1995 r33 gtst
Hypergear atr43ss2
Z32
750cc bosch injectors
255lph walbro fuel pump
greddy copy plenum
Stock tb
Fmic
Blitz dual sbc
Power fc
3inch exhaust turbo back
288rwkw @20psi dropping back to 15. Tunned at jem. Will have sheet up once iv gotten it
  • Like 1
