Engine: RB25
STANDARD ENGIN
STANDARD CAMS
STANDARD HEAD
Modifications:
HKS TO4r Turbo KIT
HKS super drager cat back exhaust (3.5 inch)
HKS S type front mount intercooler (custom piping)
Apexi AVCR boost controler
Apexi Power FC
Sard 850cc injectors
Z32 air flow meter
600hp walbro intank fuel pump
Power:1 bar = 279.6 kw @ tires
406.8 nm touque
queensland raceway time.... 58's
Edited by flyline
93 R33 GTS-T
GTR Intercooler
Tomei fuel pump
Apexi pod filter
Greddy Profec B Spec II
Standard turbo
Rebuilt engine
Standard head
3" dump
Big body highflow cat
Straight 3" to Trust cannon
Apexi pfc
z32 afm
Creatd motorsports 720cc injectors
14 psi bleeds down to 12psi (crap actuator)
206.8KW
Tuned at Creatd Motorsports
R33 gtst 1995
Nismo thermostate
Nismo high flow fuel pump
Nismo 550cc injectors
Nismo flywheel
Excedy custom clutch
Eagle conrods
ARP head studs
Arias pistons & rings
Acl engine bearings
Sard sports magnetic oil filters
Sard annodised aluminium cooling oil block
Sard fuel regulator
Nissan N1 oil pump
Nissan water pump
Apex power FC
Greddy remote switching system
Greddy boost controller
Greddy oil catch can
Greddy blow off valve
Greddy intake plenum
Fujitsubo exhaust 3''
Catco stainless high flow cat converter
3" dump pipe
Splitfire coil packs
Front mount intercooler
Custom turbo intake pipe
Custom air box & cold air duct
HKS valve springs
HKS cam shafts 256-intake
HKS cam shafts 264-exhaust
HKS turbo kit GTRS
Bosch Z32 air flow meter
Billion super solid coolant line
40mm radiator
259.4rwkw @ 16.5 psi run in tune
Fuel used - BP Ultimate
second dyno we got lots more torque
Edited by WARLORD
96 SII R33
just had a tune got 222.7rwkw @ 1.0 bar with following mods;
- full exhaust (high flow cat)
- avcr
- pfc
- fmic
- fuel pump and reg
- pod
- iridium plugs
- adjustable exhaust cam gear
- standard turbo
Edited by ICER33
not a turbo upgrade put happy with my result...
stock R33 S2 with only the following
just jap fmic $349
custom exhaust(split dump, 3"system, hiflo cat) $1250
Greddy profec B II $390
Total spent from stock $1989
205.4rwkw at 12psi
hits 11psi by 2300rpm, hits 12psi by 4500rpm for a fraction and drops to 10psi by red line.
r33 sII
Stocker motor
Garret gt30R on top mount staino manifold
Tial gate
740cc injectors
Greedy plenum with infinity throttle body
600x300x100 coller with 3 inch pipework
removal of air flow meter
Microtech LT12
turbo Smart Eboost 2
Bosch 044 pump
Straight through exhaust, no cat or mufflers and screemer pipe
Bilstein coilovers
Malpassi fuel reg
Exceddy clutch on the 3rd one!
392rwhp @ 18PSI dynoed by ovaboost
car has done about 30000kms with this set up and still going strong.
hks 3037 (.68 rear housing)
trust high mount manifold
hks 50mm external gate
550cc injectors
bosch 040
q45 afm
apexi power fc
greddy profec b spec II
hybrid FMIC
3 inch straight through exhaust from turbo back
Got a retune after replacing my cat & crank angle sensor
Highflow by Precision
650cc inj
Sard Pump
Link Ecu
Sard Pressure Reg
3'' Ex with 5'' Stainless Cat
Splifire Coilpacks
232.2 rwkw on 18psi Tuned By CRD
R33 4door automatic 1996 s2
3" straight thru
Hybrid intercooler
pod
stock ecu,motor,fuel pump,coilpacks,injectors,etc :)
BP Ultimate 98
174rwkw at 5psi tuned by (west torrens dyno centre)
Edited by R334door(s2)
Update
just had a retune 9 Aug 07
no mods from below except 98 RON BP ultimate
more timing added with the boost sneaking to 16PSI then dropping back to 13.5 PSI
235 rwKW :nyaanyaa:
cheers
Mike
1997 R33 GTST series 2
HKS 2530 turbo
HKS boost controller
Apexi power FC
Greddy FMIC
turbo back 3" exhaust with metalcat
pod
95 octane pump fuel
1 bar boost
214 rwKw
apexi power fc
E-Boost controller
spitfire coils
bosch fuel pump
sard injectors 550cc
apexi power intake
standard airflow meter (gey!!!)
kkr 480 turbo kit - Dump/ screamer--
Front mount-
229.9rwkw - 18.psi
Gettings cams and z32 - should be a bit higher then hehe!!!
1994 Forged Nissan skyline R33 GTST
Arias Forged Pistons
GTR Rods Prepped
Sard 500hp fuel pump
Sard fuel pressure reg
K & N Pod filter
Garrett GT...
FMIC
3' Exhaust turbo back
50mm Wastegate with screamer pipe
High mount mainfold
ACL Race bearings
WOLF V4
GFB Bleed valve
441RWHP @ 15psi
All engine work done at Imports101 Tuning by Top racing
    • Incidentally, I also put v3 of the tune on the car and did an oil change from 5w20 to 5w40 to see how it affected oil pressure in the mid to high end. I'm still happier with the thicker oil and will stick with it, but clearly the system is happy with 55psi even if I'm not!
    • So the other thing I got sorted over the weekend was Z1 oil catch can install. https://www.z1motorsports.com/z1-products/z1-motorsports/z1-q50-q60-30t-baffled-oil-catch-can-kit-p-23546.html It was a good kit, most importantly it came with preformed silicone hoses in the right shapes rather than trying to bend/join regular straight rubber hose. It did come with crappy spring clamps not proper hose clamps so I ditched them On the down side, it is made for LHD cars and RHD cars have the main ECU harness running straight through that location, I ended up bending 2 mounting brackets so the loom is up against the brake master cylinder compartment wall to make room for it....otherwise everything fit without modification Intercoolers off on both sides, but there was enough room to get everything done without disconnecting (and therefore having to re-bleed) the coolant lines. Each is mounted with 4x 12mm headed bolts, plus in and out side hose clamps (7mm headed, nice) and 3 electrical connectors on the navigator's side which were a real pain to undo (probably for the first time in 13 years).   Also one of the mounting bolts on the driver's side was cross threaded, thanks Infiniti/Nissan workshop mechanics. On the navigator's side, the catch can plumbs into the factory hose that goes from the cam cover PCV back to the intake.  This is the 2 new hoses in place. All simples and direct fit On driver's side, there is a bracket provided that mounts to the throttle body, they even provide slightly longer bolts to allow for the bracket thickness which is nice (although, they don't have captive washers like the factory bolts of course) In that pic the main loom brackets are not in place, once I had "adjusted" them across it now sits up against the panel and just clears the OCC The remaining problem with this is emptying it; currently you have to remove the 3x m4 bolts that hold it to the bracket and both banjos to remove it (probably dropping the banjo washers at the same time) pull it apart to empty then replace. I do have some fittings coming for a remote drain from underneath that will also add a little capacity...it is very small and will need to be emptied every oil change to be sure.
    • Noise sounds to me could be either wheel bearing related (have had similar from bearings going) or that tail shaft is still loose. Or something like a heat shield touching the tail shaft.
    • You wouldn't get away with saying the opposite, if you were there.
    • Do some wool fluff testing on the vents
