247.4rwkw
R33GTST
Z32 AFM
GCG High Flow - R33 exhaust housing (not vg30)
3" Batmbl bellmouth dump --> Catco Cat --> 3.5" Kakimoto with 2 mufflers
S15 injectors 450cc
Tomei Fuel Pump
Turbtech boost valve
18psi - running back to 16psi
Stock Airbox
450x300x76 FMIC (Justjap)
Full boost actually comes on earlier on the street in 4th than the dyno indicates. 1st and 2nd gear not quite.
Tuned at MRC Castle Hill - Mark (Top Bloke and good tuner)
Edited by benl1981
R33 gtst Rb25
Z32 afm
splitfire coils
sard fuel reg
tomei metal head gasket
hybrid intercooler
garrett GT3540 turbo with .82 rear
tial 38mm wastegate.
Apexi power fc
Blitz sbc id3 boost controller.
etc etc
Makes 300hp @ 14psi on a safe tune as it needs to get me to work daily.
Just got it back today and quite happy with the result. Will post up dyno chart if i can get it on my computer
Mark at godzilla tuned it. did a good job
R34 GTT RB25DET NEO
everything stock except:
K&N intake
dump-front-metal cat-hipower silent
avcr - 0.7bar(10spi) to be exact
safc2
coilpack+sparkplugs
serviced(oil change+filter)
= 279.9 rwhp = 208.something something rwkw
will post result soon
Edited by lcy
Sorry mate, though you could've edited my first post....
My car spat out 201.7rwkw on 13psi with split dump and screamer, big cat and two mufflers, jjr front mount, power fc and avcr. Turbo lasted 5 weeks so my gt3076r is getting built as we speak, along with 550cc injectors hopefully will get over 250rwkw on around 16psi.
hi i have got 260hp/195kw with the following:
dyno dynamics dyno on shootout mode
standard turbo
gtr front mount
dual stage boost controler 13psi
blitz sonic power pod in closed box
modified entry plenum
3'bell mouth dump pipe high flow cat and katimoto cat back
standard computer
standard evrything else
MODIFICATIONS AND SPECIFICATIONS
1998 NISSAN SKYLINE R33 GTS2.5T
40TH ANNIVERSARY EDITION.
2.5 litre twin overhead cam straight six standard motor, never openned.
Mechanical Nismo Selective 1.5 L.S.D. diff
Nismo G Max II clutch
Tein coil over height and ride adjustable
Super advan mags (powdercoated black) with 245/255 Yokohama AVS102 tyres
Hicas lock out [individual tie rod ends]
Whiteline adjustable nolethene bushes for camber/castor at all four wheels
HKS triple layer dry pod filter
Z32 Mass Air Flow Meter
SARD fuel pressure regulator
555 Nismo injectors (yellow top colour coded)
Splitfire coils
Blitz 700x600x70 fmic (anodised blue)
HKS IV electronic vacuum controller (boost controller)
Blitz turbo timer
Apexi turbo boost gauge in custom s/s holder
Greddy gauges x3:oil pressure, oil temp, exhaust temp, mounted in a dash pod
Superslide carbon fibre adjustable rear wing
Alloy oil cooler with stainless steel braided lines
Apexi alloy radiator
Cusco high pressure radiator cap
D1 oil catch can
Master cylinder brake brace stop bracket
Project mU front discs [brakes]
Braided stainless steel brake hoses [full kit]
90mm exhaust with HKS Hyper 120mm s/s muffler
Cusco front tower strut bar
Garrett GT3076 WG turbo with 100mm fluted inlet
Custom braided oil and water lines to turbo
HKS 40mm external wastegate [18psi spring rate]
HKS cast low mount manifold extrude honed and flowed
Custom alloy intake pipe
Custom s/s split dump and front pipe
Nismo 500hp fuel pump with 12volt power feed
Tomei adjustable exhaust cam pulley
Tomei Poncams 256 degrees/8.5mm lift
Apexi Power Full Computer with Hand Controller
Alpine MP3 player and 4 x coaxial speakers
300kph Nismo speedo
Carbra
SAAS/Momo leather steering wheel
Razo gearknob
Razo accelerator pedal
Custom holder for hand controller
Custom grills on front bar
Custom s/s front bar braces
Custom rear boot lid spoiler trim
Custom stainless steel heat shield around turbo
Custom EVC mount on steering wheel cover
Odyssey fully sealed gel battery and custom mount
External wastegate, manifold, and turbo exhaust housing high temp coated
Stock Internal RB25DET
HKS 3037 Pro S turbo kit, 56T A/R 0.68
HKS adjustable internal wastegate
HKS Stainless steel split dump pipe
HKS Front pipe
3" decat pipe
HKS Silent High Power stainless steel catback exhaust
HKS 3" alloy intake pipe
Apexi Power FC
Apexi Power FC Boost control kit
Apexi Power Intake Pod filter
Blitz LM Front Mount Intercooler
Nissan Z32 AFM
Nismo fuel pump
Nismo 555cc injectors
R.I.P.S custom washer bottle/oil catch tank with -10 lines
Custom black radiator air deflector
Exedy heavy duty clutch
Splitfire coils
Fuel purge system fully removed
Alloy radiator
NGK BCPR6ES spark plugs
95 octane
270rwkw on 17psi and only using crappy 95octane fuel
R33 Series 2 GTST
3" Split front dump, high flow cat, 3 inch zaust.
FMIC
Greddy EBC
Walbro FP
Fairly Hot day, BP Ultimate 98 octance
183.4rwkw @ 11psi
Edited by dnbutts
Guest Joeyz
Hi all
Hi-flow Turbo - GCG
Exhaust cam gear - Adjustable Greedy
Adjustable fuel pressure regulater - Turbosmart
500hp intank fuell pump - Walbro
Z32 AFM
NGK Irridum spark plugs
Shell V-Power Racing Fuel
3" Exhaust
FMIC - Greedy
244.9rwkw
Update
Tomei Pon Cams
Sard 700cc Injectors
Now Getting 270rwkw on 1.2bar/18psi
RB25
GT30/40
splitfire coils
45mm ITS gate
GReddy intake
80mm TB
550cc Inj
EMS Stinger
blah blah blah
made 270rwkw @ 18psi on ovaboost dyno (through a built auto), so its very reliable accurate power =D
Insane to drive, over 150kg of stereo gear in boot and have no traction in 1st + 2nd
Short list of mods:
RB25det spec 2
GT3582R .82ar
Jun style intake
90mm throttle body
550cc Delphi top feed low impedance injectors
JGY fuel rail
Aeromotive FPR
Walbro 255hp fuel pump
Tial 44mm v band waste gate
Hallman boost controller
3" ss turbo back exhaust
Top mount exhaust manifold
Apexi Safc 2
Apexi ITC
93 pump gas
Spec stage 3 clutch
Synchronic BOV
FMIC
Z32 MAF blow threw
This is a 2698lb with driver in it 240sx.
We had some problems with the boost creep so we could only set it at 11 psi but as you can see it creped up to 13.5 or so at about 6100 rpms. Also had some problems with my coil packs.
This is wheel horse power not in shoot out mode.
Correction factors were
77deg. F
60% humidity
60" of mercury
Intake temp was 90deg F
Car pulls like mad all the way to red line. I am very happy with the car as is but I'll more then likely pull the exhaust manifold off and fix the creep problem.
Edited by JonTurpening
    • Also did some work to the shed and a massive clean out of stuff. It's now got a small fab/dirty room and has helped keep shed cleaner. Built some new work benches and re organised things also got a TV out there so good having something playing while working on the cars. Got a pedestal drill and linisher off a mate that need to pick up too.
    • First thought, have your current injectors flow tested. If they test fine, keep the diagnostics going. It's not the injectors. If the injectors are the issue, find some new or used (cleaned and flow tested) injectors.  While I really love a good excuse to get a modern ECU installed, just needing new injectors probably isn't a good enough reason to do so.
    • A bit from column A, B and C. Mainly C   Update time, after deciding it was time to tick off a bucket list goal I finished up full time at MSR and have gotten back behind the wheel and making progress on the S15. Goal has been to drive Bathurst at an event and I have had my entry accepted for Challenge Bathurst in November. Since I don't want to go unprepared I need it running to test and get comfortable.  Been chipping away at it and started by stripping inside, getting it all cleaned and sealing some holes up. With stripping inside I removed the whole wiring loom and found a few surprises.......... its pretty butchered and shit branching and I'm not a fan of the haltech fuse boxes so it's all out and trying to come up with a plan to rewire it all either new fuse/relay box or pdm.  I haven't been happy with how I did the intercooler mounting and been wanting to tuck it up under rad support. O e issue with that is headlights will need a decent trim or get replacement covers. Took the time to mount it with some stand off's and new hardware. Stands are some m8 button bolts, washer, aluminium tube and factory radiator top mount rubbers. It's nice and solid also stiffens rad support which still requires some trimming. Bonus of factory rad mounting is used all factory hoses just need to weld a pressure cap to radiator now. Got sensor block and fuel filter mounted. Plan today is to get vac lines all sorted with push in nylon tube and design oil cooler mounting solution.  Been driving BRZ a heap and went out to Morgan Park for time attack and went pretty well for a wet day. https://youtu.be/gAlQgcQpWj4?si=kojOAOjhhX_X3AXR Getting pretty comfortable in it now and want to do a few more bits to it but restraining myself as don't need 2 race cars at the moment.
    • @sunsetR33 There is obviously a huge culture gap here. There is nothing in place like this in Australia, where if you fit a Mines branded pipe and later replace it with a Jun branded pipe, both pipes are essentially identical - BAM - huge penalties! Where is the Mines pipe?? You can't have a Jun pipe when you said you had a Mines pipe!  Makes no sense to me. Surely makes no sense to anyone else here either.  I'm sure a lot of us would agree that our registration/engineering system is pretty stupid at times, but it's not that stupid.  *** More serious question here. If you replace a factory rubber hose with a silicone hose, is the car illegally on the road now? Does it become legal if you have certification of what brand the silicone hose is? Then would it become illegal again if you replaced that silicone hose with a difference brand of silicone hose? And then would it become legal again if you had certification of the new brand of silicone hose?  I really want to know that answer to that question.
    • Good you making progress with this rig. Aluminium welding is painful to learn, have you got a pedal as I found it so much easier with one. If that's the AMG I think it is, you would working with Benny?
