Rb25 Turbo Upgrade, All Dyno Results
Nacho Vidal
r33 93' gts-t
hks fmic
3 1/2 inch exaust, stainless manifold
t04e garrett
38mm ext. gate
greddy profec bII ebc
jjr coil packs
microtech lt12
made 249.4rwkw on 1.0bar
1995 R33 Gtst
LT12's
Boost (7-8 PSI)
BP Ultimate
T04e
External Wastegate
FMIC
3" Turbo back
POD Filter
Bosch 040 Fuel Pump
210kw
1995 R33 series 1.5
PWR front mount
sPlit fire coil packs
stock boost
stock turbo
iridium plugs
lighten fly wheel
auto diff I think higher ratio
pod filter
98 octane pump fuel
stock fuel pump
stock internals
full 3" exhaust Welded turbo back
dyno about 2 months ago 245HP 183KW
Very happy on stock boost
Soon SAFC to be tuned and boosted to 10psi hoping to make it over the 200KW mark :)
Edited by simonyoungr33
1995 R33 Gtst
LT12's
Boost (15 PSI)
BP Ultimate
T04e
External Wastegate
FMIC
3" Turbo back
POD Filter
Bosch 040 Fuel Pump
219kw
1997 R33 GTSt:
Head:
HKS 256, 264 cams
Tomei valve springs
Brand new OEM valves
Brand new OEM guides
COMETIC 1.3mm Headgasket
Bottom End:
Mahle pistons
SPOOL rods
ACL Race beaings
ARP Mains and Rod bolts
Intake:
4inch HPI pod filter
Custom 4inch intake pipe
Tube and Fin intercooler kit
Greddy plenum
Fuel:
Nismo fuel pump
Nismo 740cc injectors
Turbo and Exhaust:
Garrett GT3067.82
6BOOST manifold
Synchronic 50mm wastegate (off turbo housing)
Custom dump pipe
Fujitsubo exhaust
Ignition:
Splitfire coilpacks
ECU:
Haltech E11V2
Tuned on E85 bleeding down to 16psi.
325rwkw
RB25 NEO
VG30 Highflow Turbo
3" exhaust with "highflow" cat
Z32 AFM
Sard 550CC injectors
HKS Adjustable Cam Gear
Power FC (tuned by Paul @ Chasers)
Blitz SBC-iD3 Boost Controller
223rwkw on 12.5psi (bleed down to 12psi)
247rwkw on 15psi (bleed down to 14psi)
it made ~270rwkw on 18psi, but i need to go and get the printout for it
1993 r33 gts-t skyline auto
kkr480 internal wastgate turbo
stainless steel low mount manifold
full 3 inch exhaust
turbosmart manual boost controller
turbosmart dual port BOV
stock intercooler off and toyota supra
walbro 500hp fuel pump
stock injectors and fuel pressure reg
r32 ecu remapped
z32 air flow meter
acl race series 1.3mm stainless steel head gasket
splitfire coilpack
stage 2 shift kit from mv automotive
ran at 20psi made 226.4RWKW
Edited by nathan0511
R34 gtt neo manual
Stock ecu
Stock turbo
Hks Hi Silent ss cat back 3"
X force Hi flow ss cat 3"
JJR 3" ss dump
Prof spec b boost controller 10psi low set 11psi hi set
Fmic
apexi pod
Shell V power
212.3 awkw (on hi boost setting)
dyno'd at ultimotive (Phill great bloke)
cheers
1989 C33 Laurel
S1 R33 RB25DET
Apex'i RC6 Turbo
Apex'i Steampipe high mount manifold
38mm External Gate
Apex'i power FC
Hiflowed injectors 550cc
3 inch dump with straight pipe
HKS death pod
Walbro 255l/hr fuel pump
246.8rwkw @ 16psi on turbo tune's dyno
1997 R33 GTSt:
Head:
HKS 256, 264 cams
Tomei valve springs
Bottom End:
Mahle pistons
SPOOL rods
ACL Race beaings
Intake:
Greddy plenum
Fuel:
Nismo fuel pump
Turbo and Exhaust:
Garrett GT3067.82
6BOOST manifold
Custom dump pipe
Fujitsubo exhaust
Ignition:
Splitfire coilpacks
ECU:
Haltech E11V2
325rwkw
UPDATE
HKS 3.75inch exhaust
Another tune with a touch more boost.
Still have the bleed problem but its better than before.
Standard motor other than forged pistons.
-Wolf 3d V4 tuned by C&V
-15Psi
-Optimax 98
-Machined standard turbo with larger compressor and exhaust wheel built by Precision TurboChargers.
-Just Jap FMIC
-Just Jap single dump pipe, unknown cat back 3"
-K&N pod
-500hp fuel pump
251 RWKW, nice smooth power curve
1991 R32 coupe
S2 RB25det + stock turbo (pretty much a full stock motor and turbo)
Link G3 ecu
full turbo back exhaust
fmic
apexi intake
229.3rwkw @ 12.5psi
  • Split fire coil pack
  • Turbotech controller set to 12psi
  • Apexi cooler
  • K&N Filter
  • Full exaust
  • Greddy blow off
  • Mines ECU
  • Stock turbo, fuel and everything else.
208 Rwkw @12psi
97 r33 gts't
apexi power fc & hks evc
gcg high flow turbo
3" turbo back exhaust
r34 smic
pod & bov
boost set @ 12psi
=222.5rwkw
tuned at envy imports at brookvale. great customer service and awesome tune. thanks guys.
