Series 2 R33 GTSt, RB25DET, 188.89 rwkw or 253.3 rwhp.
Stock motor at 170,000 k's.
Stock turbo at 12 psi :EDIT:
900cc JECS injectors
Z32 afm
walbro 341
600x300x100 front mount
Power fc
Pod filter
HKS split dump
3inch front pipe, stock cat, 3 inch kakemoto catback.
BP 98
Tuned by me and checked by Rotomotion.
r33 s2
hks 2835 pro s
3" exhaust from dump
unknown catco cat
nismo 740cc
yellowjacket coils
bcpr7es plugs
z32 afm relocated to cold pipe
4" pod to turbo
powerfc
bp98
china cooler
koyorad
nismo fuel pump
240rwkw at 19psi drops to 16psi
something is restricting making anymore power, but happy with 240 for now
will post dyno sheet later
Stock rb25
FMIC
MICROTECH LT12s
3INCH TURBO BACK EXHAUST
8PSI
190.4kw
with a bad missfire, at 10psi it was making 180kw @ 3700 revs with a bad missifre, going to replace coilspacks and retune, MICROTECH ftw =p
Stock RB25 Motor
Go fast bits....
GTX3076 .82
Link G4 ECU
FMIC
3" Stainless turbo back
Splitfire Coils
Pod / Custom Air box
Gizzmo IBC
Sard 840cc injectors
294rwkw @ 18psi - Left it there as still running stock internals. turbo capable of much more.
r33 s2
hks 2835 pro s
unknown catco cat
nismo 740cc
yellowjacket coils
bcpr7es plugs
4" pod to turbo
powerfc
bp98
china cooler
koyorad
nismo fuel pump
0534_001.pdf
Got my car tuned but its going back soon.
Anyway its an R33 GTST Series 2 with the following:
Unopened RB25DET
HyperGear ATR43SS-2
3" JJR Bellmouth dump
HKS Hi Power Silent exhaust
Yellow jacket coils
NGK Copper plugs BCP7RES gapped to .7
Genuine HDI FMIC
Venom 5" body 100cpsi cat
Nismo 740cc injectors
Bosch 040(was failing during tune)
Nismo FPR
Greddy profec b spec 2
3" metal intake with Apexi power intake filter
Power FC tuned by Advan performance
Made 244rwkw on 11.4psi. That is with the boost controller set to 100%. That is as much as we can get out of it. With about 15psi, we should see about 270rwkw and 17psi about 280rwkw. 20psi should see 300rwkw on regular fuel pump.
Ive fitted a GTR fuel pump in there to fix the fuel pump issues. Probably will swap that with a brand new 040 pump or run it as a lift into a surge tank. Last printed dyno shows about 238rwkw on 11psi, should have printed the previous runs :P
Got it retuned, the AFR is perfect. Running more boost 15 low 19 high. Oddly enough high boost is seeing 250rwkw low boost is on about 217rwkw but low boost feels much stronger than the original 244rwkw on 11psi... Mind boggling. Intake pipe might be a huge restriction. Making close to 700nm of torque, it absolutely rips my face off compared to what it was before. Very impressed with the thorough tuning work done by Jez and bordy. A dyno gives you a number, but what you feel on the road is what counts and wow this is amazing. Just driving home on low boost the lift on the front end was intense.
93 R33 GTST Rb25det with forged pistons (factory compression) and stock every thing else.
550cc injectors
Z32 AFM
HyperGear ATR43SS-1PU turbocharger with updated compressor profile.
3inch turbo back exhaust
Ebay cooler
Nistune chipped ecu
3inch metal intake pipe to air box.
The most power made was 287rwkws, and average was 280rwkws @ 17psi. Very consistent result with consecutive dyno runs.
93 R33 GTST Stock bottem end rebuilt. Standard head/cams.
JJR Cam gear
720cc injectors
tomei 500hp pump in tank
power fc w/z32 afm
GTR intercooler
Greddy plenum
GT3076R .82 external gate turbo
Tial 44mm gate.
Stainless high mount manifold modified by rob at creatd.
Straight thru 3" exhaust with a Trust PEII cannon.
297.7kw on bp ultimate 98 @ 20psi.
Unbelieveable response and control.
^^^ Add some graphs ^^^^
Finished mine ages ago probably should add it..
t67dyno.jpg?t=1308909591
t67boost.jpg?t=1308909571
More in it but settled here due to injectors near max and valve springs getting loose up top.
Internally stock Rb25DET 170000ks
t67-25g
6boost
tial 44mm
freddy plenum
z32 in cooler piping
power FC
profec B II
740cc highflowed stock injectors
bosch 044
3" exhaust
Adjustable EX cam gear
Splitfires
exceedy 5 puk clutch
E85 (trent tested it at E65) Springvale stuff
Basic engine rebuild, arp head studs, commetic 1.2mm HG. Abit of porting to the head.
Spot-on inlet manifold (stock throttle body ;))
6boost exhaust mani
pro boost gate
garret 3076
lt12
550cc inj.
pump/tol 70/30
456rwhp @ 22psi.
R34 GTT 1997 w/2000 model 25det neo motor
Std internals (as far as i know :s)
Hybrid FMIC
Turbosmart stealth series plumb back bov
Splitfires w/iridium plugs
Walbro GSS341 or 342 cant remember which
3" advance front/dump
Bokka 3" 100cell metal cat
3" stainless cat back 1 res 1 muffler
Nisstune
10psi (spikes to 12 and drops to 10) rb20 actuator
201rwkw and a touch over 550nm (peak) of torque on the jaustech dyno,injectors,afm and turbo at the limit.
550cc injectors
Z32 AFM
Ebay cooler
Nistune chipped ecu
BP 98 Fuel
ATR43G3 Rb25det bolton version internally gated.
We also had a customer run the same turbo on e85 making 347rwkws with factory setup. you can find his reading in our high flow thread.
330rwkws @ 23psi using manual boost controller
320rwkws @ 20psi. No boost controller, straight of high pressure actuator.
Track footage
    • As an ex-skyline owner Going off how these things are now "modern classics", I would keep the twins and just "refresh" bits that are required for reliable power and have a car you can take out for a cruise whenever you get the itch As a idiot who cannot leave things alone Going deep into the "rabbit hole" is a easy thing to do, as previously mentioned, once you start it becomes a slippery slope, wirh lots of supporting mods, and possibly rebuilds, and unless you have a bottomless pit of funds, the car can spend most of its life sitting in the garage,  broken, waiting for parts, or building more funds For a classic like a R32 GTR Basically, a reliable OEM+ refresh, that isn't a broken garage queen, is alot better than a car that you build, then break, then fix, then break again And it isn't just the engine you need to worry about, these beasties are getting on in age, and all parts are getting, and have got, expensive, the days of picking up cheap replacement engines and other driveline parts are well and truly over The funds not spent on going a single with quality parts, and with all the other other bits required to make it happen, could be spent on refreshing alot of other parts A wise man once said "If you cannot afford 2 GTR's, you cannot afford 1", I also believe he said this about 20 years ago when you could pick up a clean R32 GTR up for around $20k My advice for a R32 GTR (the one and only true Godzilla in my mind) is to think holistically about the whole car, the body, the power train, the suspension, the brakes, and the driveline SAU is a wealth of knowledge with decades of Skyline experience,  from stock, to OEM+, to modified to varying degrees, to full on or weekend or dedicated racecars, as well as full on money pits that rarely leave their garage Treat the old girl nice and give her what she deserves, you are a lucky man to own such a classic car
    • For that price you could buy the hypergear turbo (big fan as I run one) and the Haltech ECU..
    • +1 for the Elite 2500. Get some new knock sensors while you are at it (pretty cheap), look up the TAARKS Nissan knock sensor kit. You may also want to get new coils (R35gtr) while your at it (assuming your on stock ones), as they are a liability. Mine started right up and idled fine on the base map. Also go MAP over MAF, as said above, Haltech make this super simple right out the box. Another fanboy of DBW here, Outsider Garage from your neck of the woods make some nice conversion gear for the R33 (that’s where I got some of my gear from).
    • Nvm ignore this I read it wrong
