93 model R33 GTST Forgied CP pistons, valve springs and stock every thing else.
800cc injectors
600x300x75mm Front mounted cool
Brae high mount exhaust manifold
HPVA 50mm external gate plumbed back.
Xforce 3inch Cat back exhaust
100 Cell Cat
Profect B electric boost controller
HyperGear Latest Ball bearing ATR43G3
4inch intake pipe
Adaptronic Plugin
Max power is 376rwkws @ 23psi E85 Fuel
Please check our thread for current V older G3 result.
Video footage:
[image]
[/image]
Also ATR45 AKA ATR43G4 turbocharger on same car using same mods making 431rwkws @ 26psi. Not a responsive turbo, but super strong mid top end power and torque.This turbo should be able to pull some reasonable quarter times.
Dyno sheet:
Tuning video:
New turbo and tune are finally done
Had to change the HKS wastegate to a turbosmart one due to it breaking
98 R34 GTT
RB25DET
Hpi turbo to cat downpipe
Hks exhaust
Hks mushroom filter
R33 GTR Intercooler
Hpi turbo to cat exhaust downpipe
Apexi PowerFc
Bosch 044 fuel pump
HKS GTRS Turbo
Turbosmart Wastegate
Greddy Profec B boost controller
Was 206 on 15psi
Now is 220 on 16psi
220
800cc injectors
100 Cell Cat
HyperGear high flowed R33 GTST turbocharger using SS2.5 CHRA inside factory compressor and 21u turbine housing.
3inch intake pipe
Adaptronic Plugin
Max power is 341rwkws @ 21.5psi E85 Fuel
Super responsive power.
standard RB25 series1
GReddy T67 25G 8CM
GReddy manifold and gate
RB20 HKS 264 8.5 cams (no VCT)
RB20 ecu nisstuned
sard 550cc injectors
standard intake manifold
BP 98 fuel
285kw 17psi
311kw 19psi
320kw 20psi
E16C0E13-7A45-4DF1-81D6-4948F531E79F-252
  • 3 weeks later...
R33 -93 4 door
HKS GT3040 Top mount turbo
HKS Manifold
HKS 54mm external wastegate
HKS down pipe
HKS screamer pipe
Stainless cat back exhaust
Blitz airfilter
HKS injectors
Splitfire coils
GTR fuel pump
Greddy Rad
Thrust front mounted oil cooler
Thrust front mount inter cooler
Z32 air flow meter
Blitz DSBC-R boost controller
Steel head gasket
R34GTT 25det neo
Nistune
FMIC
Turbo back 3" stainless (de-cat)
Splitfires
1Bar boost
Bosch 044 fuel pump
stock injectors
Stock Turbo
Stock AFM
Stock internals
300.6 RWHP
13.6 1/4mile
Edited by Luke Vincent
96' R33 GTS-T with:
- Momo 3" turbo back exhaust with 2 mufflers
- Pod filter air intake
- RB20 wastegate actuator
- Walbro 255 (500hp rated) in-tank fuel pump
- FMIC
- NIStune on an R32 GTS-T ECU
- Greddy Profec B-Spec II boost controller on 12psi
Edited by brentos_mentos
s1 r33 rb25det
unopened motor
dw301 intank fuel pump
jecs 550cc injectors
turbosmart fpr
hypergear ss2 turbo
vipec ecu
standard manifolds
3inch intake pipe
fmic
3inch turbo back exhaust
npc organic clutch
270rwkw@17psi
Edited by mzol89
800cc injectors
100 Cell Cat
4inch intake pipe
Adaptronic Plugin
ATR43 SLSS2 Turbocharger
Got this tuned today. Big thanks to Status tuning as usual.
Just out of curiosity of what the 10cm L2 turbine can pump, We tried every thing to squeeze power out of and The maximum we've got it to was 385rwkws on 24psi. The car refused to make any more power after this.
At 22 psi it made 374rwkws so basically identical to SS2 at same boost level.
This goal of this turbocharger is to make better power then a T67 while having the same response to a 20G.
I've overlaid three readings from:
Our brand new SLSS2 turbocharger
V
Latest SS2 turbocharger that has the identical compressor setup on lower boost level.
V
The highest reading of a T67, Greddy manifold, externally gated.
All on Rb25det with stock cams.
800cc injectors
100 Cell Cat
4inch intake pipe
Adaptronic Plugin
HyperGear ATR43SS2 VNT Turbocharger 384rwkws @22psi, full boost by 3500rpms.
Hey Guys,
I have been slack lately and didnt post the results, i WILL get Dyno sheets soon but for now -
Car made -
311rwkw on pump 98
320rwkw on E70 at gate pressure of 1 bar
340rwkw on E70 at low boost of 18-16psi
357rwkw on E70 at high boost of 21-18psi
Full boost at 3900ish
The dyno run shows 360.7rwkw which was its highest run but it was having fuel supply issues, it was retuned safely to 357rwkw where it sits now. The turbo and exhaust flow are basically on their limits.... to go higher i will need to do the clutch again, more fuel system upgrades and a bigger turbo, its so nice to drive now that any more would just spoil it.
Basics that got me to this level -
RB25 NEO stock internals
Garrett 3037 - 56T 0.82 rear
6Boost manifold, custom dump into 3"exhaust (Very quiet)
Tial 44mm MV-R with screamer or plumb back setup
Plazmaman Pro Series Thottle body/plenum/cooler & piping
Xspurt 1000cc injectors
HKS fuel rail - 6 fittings and 3/8 line i think
Bosch 044 pump, Sard Reg, Billet filter
Haltech PS2000 wire in with ethanol sensors and wide band (Full Flex tune by JEM)
HKS EVC 5
HKS Exhaust Cam gear and full Gates Racing timing belt kit
Tomei type B poncams, Performance valve springs and retainers
The list keeps going, but i just realised all this info is in my Signature :P Cost heaps to do but it an absolute dream to drive daily and is a laugh on boost!
Dyno run on E70 -
So as impressive as this result was last year we have decided to improve it, we had an injector issue which required them to be replaced with the new XSPURT 2000cc items, due to a full flex retune being needed we decided to improve the spool and power too.... TS was initially the plan BUT then we decided to go left field and try a new turbo, instead of trying to make old tech work better I decided to take a punt with a new billet item and well the results need no further explanation -
217352_275271485949967_794567082_n_zps79
^ nice results..
Haven't seen a lot of guys running GTX35 units on RB25s, I did and heres some results.
R33 GTST
(Main mods)
Stock standard RB25 (r33) bottom end
Recoed RB25 NEO head w/ 256 poncams
Greddy Profec B s2
Greddy plenum
Deatschwerks 740cc drop in injectors
Deatschwerks 300LPH fuel pump
Splitfire coilpacks
Nismo fuel reg
FMIC
GTX3582R 0.82a/r
45mm Turbosmart hypergate
GCG Highmount manifold
Permaseal metal head gasket 1.3mm
Haltech plat/pro plug in
3'' exhaust
Tomei exhaust cam gear
All work done @ JEM also.
375.8RWKW @ 20psi on BP98 ultimate.
  • Like 1
R33 GTST s2
Z32 Nistune
Stock injectors
Stock Turbo
Stock AFM
Stock Air box with HKS Panel filter
255LHP walbro fuel pump
Greddy profec b spec 2
Split dump > 3" >high flow cat > mid muffler > cannon .
Return FMIC
Low boost 10 psi 199.3 RWKW
high boost 13 psi 215.8 RWKW
dyno
Edited by xm4tr1x
yeah i said dont go over 320 so he put 20psi on it and said it is nice and solid and safe
starting to think i should turn it up - but head and block have not been touched and injectors are at 85% -
car has been off the road for so long so just wanna drive it and enjoy it and start throwing it round the track..
Any restrictions here? With your setup on e85 id have thought it would have pushed closer 350rwkw+
Nice, probably a good way to go about it.. Standard bottom end would hold up under a bit more too i reckon.
Ive got standard bottom end, head has been port and polished, apr head studs. GT3076 making 450rwhp on 25psi. which is like 335kw i think. On E85 also
nice..
with the luck i have had with this car i just wanna drive it lol and i wanna start drifting so i think that will be good enough power - i have rb 30/25 ready to be built so just need the current motor to last while i buil lol - good thing was my tuner was confident it could do more but best to be safe i guess.
    • Just a thought, but instead of restricting, is it possible to do like an "up for review" kind of thing? Where say someone who's not an admin/mod tags, it would require approval for it to actually tag? User posts with a 'tag' > Admin/Mod Reviews > Approves tag > Tag now exists kinda thing? Just came across this thread so Im not too sure if Im straying off topic or not but forgive me if i am...
    • Yes, a plan for non-action is always my first sort of plan! I'm happy to see what falls out of invision's update. I had been having some thoughts on what to do with this the other day and they all seem to have fled my memory, after various solar panel induced traumas, squeaking suspension sphericals, etc etc, over the last little bit. I'll try and recall what I had in mind and make sure that I put it into print in some form before the Alzheimer's strikes again.
    • The ability to have both a 5500 stall for launching, and a regular lockup for every other scenario is pretty sweet. Does it actually work well like that though in the real world? Would it hold up to track use and otherwise you'd never know you had a stall converter in it? If so, that's awesome
    • The thing is, once the content has been tagged we can chop and change the end result as much as we want. Its identifying the content in the first place that needs to be done regardless of the final outcome.
    • Sorry @GTSBoy I thought I'd replied here. There's a new BIG version of invision coming out soon, it might be worth waiting until that happens as it contains a lot of improved functionality for tags. My suggestion would be to add a top level page (not thread) with some info on it and then link to sub pages for various topics. We could even just start really simple with 2 or 3 pages underneath it. Those pages could just have a view (like a pre configured search result) of the tags we choose to put on it. We could have some background or an intro on each of these pages. My only issue is that while admins and mods can update the existing content to contain the tags we want, new posts can have whatever tags the author wants. That said, the reason our tags are so messy is because of that, so maybe we restrict tagging to admins/mods in edits.
