my 98 r34 gt-t
unopened rb25neo
180xxx kms
Nistune ecu
e85
Bosch 750cc injectors
z32 afm
T04e turbo
38mm turbosmart ultragate
Adjustable fuel reg
raceworks e85 pump
hdi front mount
3 inch exhaust
gfb bov
stock manifolds
stock cams
stock coilpacks
made 245kw on 15 psi
Edited by Mareko
Garage 7 just finished tuning mine today. Boost is straight off the wastegate spring 17psi and boost controller not dialed in yet as my rear brakes locked on witch put a holt to the tune.
Engine:
S2 RB25DET Unopened apart from cams.
GTSR exhaust manifold
Kando TD06 20G 10cm with 45mm turbosmart hypergate
3inch turbo back exhaust-Kakimoto cat back
Splitfire coilpacks
Tomei pon cams 256 8.5mm lift
Adjustable Tomei exhaust cam gear
N1 oil and water pump
1000cc injectors with top feed fuel rail-Tomei fpr
Freddy intake
600x100x76 intercooler with custom/short piping
Denso intank, 044 external and 2l surge tank
52mm radiator with 2x12inch craig davies thermos
HKS 13 row oil cooler with grex oil filter relocate block
That's all I can think of at the moment. Will be rebooking after the new year for 20+ pound run.
R33 GTST RB25DET unopened engine.
- Power FC
- 1000CC ID injectors
- Factory cams, cams gears, and all manifolds.
- HyperGear R33 GTST 21U OEM High flowed turbocharger
- 3 inches turbo back exhaust
- Walbro 470L/H Fuel pump
- 4 inches induction pipe
- Split fire coil packs
- 600x300x76mm front mount cooler
- Tuned by Trent Hewitson, Chequered Tuning.
312rwkws @ 19psi E85 fuel
- Power FC
<script pagespeed_no_defer="">(function(){var g=this,h=function(b,d){var a=b.split("."),c=g;a[0]in c||!c.execScript||c.execScript("var "+a[0]);for(var e;a.length&&(e=a.shift());)a.length||void 0===d?c[e]?c=c[e]:c=c[e]={}:c[e]=d};var l=function(b){var d=b.length;if(0=d.offsetWidth&&0>=d.offsetHeight)a=!1;else{c=d.getBoundingClientRect();var f=document.body;a=c.top+("pageYOffset"in window?window.pageYOffset:(document.documentElement||f.parentNode||f).scrollTop);c=c.left+("pageXOffset"in window?window.pageXOffset:(document.documentElement||f.parentNode||f).scrollLeft);f=a.toString()+","+c;b.b.hasOwnProperty(f)?a=!1:(b.b[f]=!0,a=a<=b.e.height&&c<=b.e.width)}a&&(b.a.push(e),b.d[e]=!0)};p.prototype.checkImageForCriticality=function(b){b.getBoundingClientRect&&q(this,b)};h("pagespeed.CriticalImages.checkImageForCriticality",function(b){n.checkImageForCriticality(b)});h("pagespeed.CriticalImages.checkCriticalImages",function(){r(n)});var r=function(b){b.b={};for(var d=["IMG","INPUT"],a=[],c=0;c=a.length+e.length&&(a+=e)}b.g&&(e="&rd="+encodeURIComponent(JSON.stringify(s())),131072>=a.length+e.length&&(a+=e),d=!0);t=a;if(d){c=b.f;b=b.h;var f;if(window.XMLHttpRequest)f=new XMLHttpRequest;else if(window.ActiveXObject)try{f=new ActiveXObject("Msxml2.XMLHTTP")}catch(k){try{f=new ActiveXObject("Microsoft.XMLHTTP")}catch(u){}}f&&(f.open("POST",c+(-1==c.indexOf("?")?"?":"&")+"url="+encodeURIComponent(b)),f.setRequestHeader("Content-Type","application/x-www-form-urlencoded"),f.send(a))}}},s=function(){var b={},d=document.getElementsByTagName("IMG");if(0==d.length)return{};var a=d[0];if(!("naturalWidth"in a&&"naturalHeight"in a))return{};for(var c=0;a=d[c];++c){var e=a.getAttribute("pagespeed_url_hash");e&&(!(e in b)&&0=b[e].k&&a.height>=b[e].j)&&(b[e]={rw:a.width,rh:a.height,ow:a.naturalWidth,oh:a.naturalHeight})}return b},t="";h("pagespeed.CriticalImages.getBeaconData",function(){return t});h("pagespeed.CriticalImages.Run",function(b,d,a,c,e,f){var k=new p(b,d,a,e,f);n=k;c&&m(function(){window.setTimeout(function(){r(k)},0)})});})();pagespeed.CriticalImages.Run('/ngx_pagespeed_beacon','http://www.sau.com.au/forums/index.php?s=09d02ef78df86f5990b8293f332bd2e8&app=forums&module=ajax§ion=topics&do=quote&t=55845&p=7653780&md5check=98e788266ec448abb7f617fe94073309&isRte=1,6YgIICLrb3,true,false,L8LpuQW6MD0');</script>power.jpg
&&0){for(var>
Wow! That response is great!
Here are two more ATR43SS2 graph sent in, all E85 fuel, R33 Unopened engines. 3inches intake and exhaust, ECU, generic 600x300x75mm cooler, and E85 fuel, Peek power made at 19psi.
This is Traditional ATR43SS2:
Twicked version, conservative tune, but notice the difference in upper rev torque:
Gday all
1993 r33 gtst rb25det
Tomei poncams 256s 8.5mm lift
supertech valve springs w/ matching retainers
forged short block with cp pistons and tomei rods. Acl race bearings. Arp bolts all round.
Forward facing plenum
90mm throttle body
Fmic
Discotune steampipe manifold
Gtx3076r .82
3 inch straight through exhaust
1400cc injectors
walbro e85 lift pump, surge tank with 044
Haltech platinum pro plugin
Yellow jacket coilpacks
heaps of other good fruit too.
This is just the base tune which made 295rwkw at 17.4psi, caltex 98.
Coilpacks were holding it back on running more boost as they are on their way out, so i am converting to ls1 coils before tuning to e85. Full fuel flex system in the car ready to go.
Will update when the e85 tune happens.
Cheers
  • 1 month later...
95 r33 gts25t
Stock s2 block
Gt3582 .63
Topmount mani
44mm trust wastegate
ffp
Fmlc
Hks bov
Top feed fuel rail
Id1000 injector
Fuel feg
Bosch intank pump
Oil cooler
Vipec plugn play ecu
224kw @ 8psi
308wk @ 18psi
7400rpm limited
Bp 98 fuel
  • 3 weeks later...
R33 gtst s2
Unopened motor
Tomei PonCams
740cc nismo injectors
Walbro E85 Fuel pump
Garrett gt3076r .82 internally gated
Powerfc ECU
3.5 inch exhaust (no cat)
E85 United
340rwkw @ 20psi
Tuned by: Trent @ chequered tuning
  • 1 month later...
S1 c34 stagea
Rb25det s2
Hypergear atr45sat iwg
Apexi power fc with boost kit
Splitfire coil packs
Z32 afm
Xspurt 1000cc injectors
600x300x76 front mount intercooler
Bosch 023 fuel pump
3 inch exhaust with mid muffler no cat with bellmouth dump
265rwkw bp98 at 20psi
Has some form of restriction limiting timing up top
Edited by fmlycar
  • Like 1
  • 3 weeks later...
Stock s2 rb25det
Arp head studs
Cometic head gasket
Camtech 264 duration & 9mm lift cams
Freddy plenum with q45 throttle body
Steam pipe high mount manifold
Mta 35r with .82 rear housing
Turbosmart 45mm wastegate
3 inch exhaust
Walbro 255 lift pump
2 x Walbro 460 in surge tank
-8 fuel lines
Turbosmart fpr1200
548.5hp @ 22psi on e85
Tuned by Matty at PITS.
Edited by rb20lover
Upgraded turbo to GTX3071R .82 rear internally gated
Blitz return flow FMIC
Ceramic coated split dump pipe, custom 3" front pipe, Venom 100cpsi 3" cat
Nismo fuel pump rewired with relay
Splitfire coilpacks
Metal intake pipe
Z32 AFM
Standard airbox
Nistune
98 RON fuel
263.8rwkw @ 16psi (wastegate pressure)
Started getting detonation issues probably due to the return flow FMIC, left the tune at wastegate pressure for regular track use.
Green line is stock turbo
Changed FMIC to Plazmaman pro series
Apexi pod filter
Walbro 450lpr fuel pump
Tomei Type L FPR
Nistune upgraded with Flex
273rwkw on 98
309rwkw on E85
  • 5 weeks later...
Suuuuuuuuuuuu tutuututu #keepingdosing bitches!
R33 Series 2 GTS-t with over 300000km (Edward Lee's Special Edition, dash says 157xxx)
  • Stock Motor with (most likely) 350000km, based on wear and tear of interior, bushing etc.
  • Stock cams
  • Stock valve springs
  • Stock valve seals
  • Stock head
  • Stock head gasket
  • Stock bottom end
  • Stock intake manifold
  • Stock exhaust manifold with havoc gate modification
  • ARP non 2000 studs, torqued to 115nm
  • Plazmaman Swept back piping kit
  • HDi eChina FMIC
  • Mick_O 4" le secks dose pipe :)
  • 3.5" Turbo back exhaust by Impossible Fabrications (3.5" mid muffler, 3.5" resonator, 3.25" HKS rear muffler)
  • 5" body venom cat with 3.5" inlet/outlet
  • 45mm Turbosmart Hypergate EWG, plumbed back after cat hehe
  • 875cc Siemen DEKA V Half Height Injectors (8 hole)
  • Walbro 460L
  • Turbosmart FPR1200
  • Splitfire Coil Packs
  • Adaptronic 440 Select Plugin
  • Hypergear SS2 with Ceramic Ball Bearing CHRA (circa 2016)
Special Thanks go to:
  • Tao at Hypergear for making a turbo that he doesn't usually sell
  • Mark at MRC for coming in on a Saturday so that I could use his dyno and telling me to push it further
  • Andy at Adaptronic for countless support e-mails (not for this car, for another car)
  • Grub at Impossible Fabrications for making a cheeky exhaust system
372kW @ 1.75bar, 1.5bar by 4100rpm
Self Tuned
  • Like 3
  • Stock cams
  • Stock valve seals
  • Stock head
  • Stock head gasket
  • Stock bottom end
  • HDi eChina FMIC
  • Walbro 460L
Self Tuned
Hahaha the classic uncle eddy's special
That's one strong engine though!
Now this has given me a bit of hope for mine
Very nice results too
R34 GTT RB25DET NEO unopened engine.
- Adaptronic​ ECU
- HyperGear ATR45SAT Ceramic Ball bearing Internal gated RB25 bolton Turbocharger
- JJR 3 inches turbo back exhaust, front pipe dropped before cat.
- PWR 600x300x81mm intercooler
Some updates on the ATR45SAT CBB Turbocharger. made 336rwkws @ 22psi on Pump 98 fuel, internally gated bolton.
Sorry not the prettiest looking. I just can't get same power out of fancy looking bits.
I think this turbo is too big for a 3 inches turbo back system for an R34 GTT. I can't get much more power then the G3 SAT with exhaust connected. Result above was obtained from front pipe dropped before the cat. it would be a very nice turbo to run on an external gate off an factory exhaust.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
