S1 c34 stagea
Rb25det s2
Hypergear atr45sat iwg
Apexi power fc with boost kit
Splitfire coil packs
Z32 afm
Xspurt 1000cc injectors
600x300x76 front mount intercooler
Bosch 023 fuel pump
3 inch exhaust with mid muffler no cat with bellmouth dump
265rwkw bp98 at 20psi
Has some form of restriction limiting timing up top
I had a similar issue with the ATR45SAT with timing being limited up top. I made 289rwkw on 98, on my 25NEO. Told it was most likely exhaust, i have 3" bell mouth dump to 3" straight pipe. What brand dump/front are you running?
Please add above tech Chitchat in my thread I will reference the type of exhaust fabrications and cooler side of things to get the most out of it. And please keep this thread dyno sheets only. cheers.
rb25det s1
stock turbo
550cc injectors
z32 Maf
Nistune with rb20 computer
Split-fire coil packs
3" cat-back exhaust stock dump and down pipe and cat
93 pump gas
Edited by slowpoke2006
My s1 rb25 33-
Greedy copy plenum
Ls coil packs with 8.8mm leads
BCPR7ES plugs gapped to .6
Id1000'sId1000's and bigger rail
sard fuel reg
Xf throttle body
S60 master power turbo
38mm turbosmart external gate
Stainless manifold
3" dumo and exhaust with high flow cat and hot dog muffler
Walbro 460
E85
Shitty compression motor 115-125.
Made 398.5rwhp on 20psi tunnwd by Horsepower Solutions.
  • 1 month later...
Hello from Norway.
My car is a 1987 Nissan Laurel C32, probably familiar to some of you. Basically Its the sister model of the R31 Skyline.
The engine setup is as follows:
Stock internal RB25DET from a ECR33. Tomei cam ex cam gear adjusted 2 deg retarted.
Vipec Plug-in ECU,
GT3076R old type 7 blade 52 trim with AR 1.06 twin scroll T3 housing.
Homemade twinscroll manifold with single 50mm Synchronic wastegate. Divider goes all the way to the valve.
Stock intake manifold for better low end torque than the junk Freddy manifold i had previously.
R33 GTR intercooler.
ID1000 injectors
472hp/347kw, 570Nm @ hubs in Dynapack, boost 1,45 bar. 99 RON pump fuel
Edited by Finken
  • Like 4
Hello from NZ!
Running a stock S2 RB25DET in my r32 coupe with the following mods:
- Greddy knockoff plenum with a 90mm TB
- top feed fuel rail + 1000cc xspurt injectors
- Hypergear ATR43SS2 internally gated turbo bolted to the stock manifold
- 600x300x80 bar and plate intercooler + custom 3" piping
- Link G4 plugin ecu
- Splitfire coilpacks
- custom dump/down pipe and 3" exhaust
  • Like 1
r33gtst Rb25det
blitz return flow
walbro255
nismo 740cc
hypergear op6 highflow
38mm tial external wastegate
power fc
splitfire coilpacks
factory airbox
z32 afm
custom intake pipe by Jem
3" dump pipe, straight pipe to a fujitsubo muffler
Car feels like a nugget down low, so much lag but goes well when boost comes on.
Does the dyno graph look normal to you guys?
Rb25
Forged / balanced 8.5:1 Comp
Lightly ported head stock valves with kelford 270° 9.35mm lift cams / adjustable gears kelford valve springs. no vct.
6boost t3 50mm gate 3.5 inch dump / exhaust. Mta750 turbo 62mm billet wheel t3 .82 housing.
Cpc plenum 1000cc inj e85
Splitfire coils haltech ps2000 cam and crank triggers custom loom.
25 psi
Edited by munro31
On 7/31/2016 at 0:16 AM, hypergear said:
get a proper PWR 600x300x89mm fmic, block bov and use a pod filter. will increase power and response by heaps.
I'd start with the cheaper options mentioned here first... my Blitz LS return flow provides 315+rwkw with better response than most RBs running similar power levels (i.e. full boost by 3300rpm) whilst providing ample cooling for hard track work.
  • Like 1
Rebuilt RB25 motor - CP Pistons/Spool Rods/ARP Hardware/Greddy Metal Head Gasket/Camtech 264/268 9mm cams, HKS cam gear, Performance Springs valve springs
Trust TD06SL2-20G 10cm turbo/GReddy High-mount Stainless Manifold/Tial MV44 Wastegate
Plazmaman FMIC And piping
1 piece dump/front/3 inch straight pipe, Jun BL Blast pipe
Pierberg lift pump, Surge Tank, Bosch 044, ID1000cc Injectors, Aeroflow Fuel Rail, Turbosmart Regulator, E85 Fuel
Haltech PS2000 ECU, Haltech Wideband
300kw-20psi/550nm torque.
Thought it would have made a bit more, but turbo seems to be out of puff. Thought about going up to say a 25G 10cm turbo, but the midrange and response is pretty awesome, so I don't really want to change much simply for a bigger number on paper.
All you need is to upgrade its compressor. Below is using one of our upgraded TD06-20G in 12cm using ATR43G3SAT compressor before and after upgrade.
R32 GTST RB30det Pump 98 fuel
ID 1000CC injectors
PFC + FMIC + 3 inches exhaust
High mount manifold + 44mm external gate
  • Like 1
Will be something I look at later on, Im just happy to have it back and running after 2 years building it haha.
Do you have any sheets for that that turbo on standard capacity 25?
What would a core changeout be worth?
Edited by R31 drift pig
R34 GTT RB25DET NEO unopened engine.
- Adaptronic� ECU
- 1000CC ID injectors
- Factory cams, cams gears, and all manifolds.
- HyperGear ATR45SAT (Pro-B 150816) Ceramic Ball bearing Internal gated RB25 bolton Turbocharger
- JJR 3 inches turbo back exhaust, front pipe has 2inches Tee.
- Walbro 470L/H Fuel pump
- 4 inches induction pipe
- Split fire coil packs
- PWR 600x300x81mm intercooler
-Tuned by Chequered Tuning Melbourne (Highly recommended)
Peek of 331rwkws and average of 325rwkws @ 22psi. 20psi @ 3650RPM. P98 fuel
  • Like 2
C34 Stagea with RB25DET NEO unopened engine.
- Nistune ECU
- HyperGear older version ATR45SAT (Rv-0 130215 discontinued) Bush bearing, RB25 bolton externally gated through exhaust manifold.
- 3 inches turbo back exhaust.
- 3 inches induction pipe
Car made 400rwkws @ 22psi E85 fuel.
On 4/23/2016 at 7:07 PM, DekA said:
Changed FMIC to Plazmaman pro seriesApexi pod filter
Walbro 450lpr fuel pump
Tomei Type L FPR
Nistune upgraded with Flex
273rwkw on 98
309rwkw on E85
Had a Turbosmart 40mm external wastegate welded to the exhaust housing
Comparison of internally gated to externally gated
Also changed rear muffler to a Dynomax VT 3" in/out
Final E85 tune with high/low boost:
  • Like 2
On 30/07/2016 at 10:53 PM, dc2low said:
r33gtst Rb25det
blitz return flow
walbro255
nismo 740cc
power fc
splitfire coilpacks
factory airbox
z32 afm
Got a retune done on the car same setup. Turbo is still laggy until nearly 4k rpm. Made some power mid and high range.
Edited by dc2low
New dyno plot
Updated my result from awhile back with:
1x 3in to 3.5in exhaust, with gate plumbed back now as opposing to going to Atmo, through two mufflers.
Walbro 460 pump, with the 120psi relief valve over the 70psi one. Fuel tank lid actually sealed now too.
Different stall converter to fit the situation, which results in more slip. Added a fair amount of restrictions to the system but got a better result because of other messing around. To avoid killing the dyno this pull was WOT at 3000 RPM as opposed to stalling the converter up. So it's actually more responsive than this shows, but the dyno didn't like it.
Still have a Blitz return FMIC, so that really isn't a restriction people.
413rwkw at.. 24-25ish psi, with about 10% slip in the converter up top.
Couldn't go higher due to Splitfires starting to really call it a day at that power level, which would be higher if it had a clutch, so for anyone reading you can probably do 460kw with ~25psi of boost before they start to miss, at least in my application.
It's pretty torquey.
GTX3582R on standard manifold, Picture of engine bay attached for dat boringness.
  • Like 10
RB25DET
Stock: ECU, injectors and rods. Intake and intercooler.
Aftermarket:
264mm cams.
Forged Pistons
Fuel pump(not sure of specs upgrade was done by previous owner)
Custom 3"dum pipe to 2.5" de-cat straight to 3.5" cannon.
Upgraded turbo (standard manifold) genuine GCG Garrett GTX 29/30 billet wheel. running wastegate pressure 12 psi.
  • Like 1
    • Major thread necro but how bad of a job is it to DIY? Looking at it online it looks like if you reuse your ring and pinion as long as those are in good condition it should be fine to just pull the axles/front cover and replace the diff that way? Or should I be replacing everything and doing preload measurements/gear mesh testing like the factory service manual mentions for the rear diff?
    • in my list I had the R33 GTR as the best Skyline. Infact I had all GTR's (33>34=32), the NSX, the GTO, the 300ZX, the 180SX, the S15 better than the FD RX7. I had the MR2 and the A80 as 'just' better. I also think the DC5R Integra looks better but this is an 01 onwards car. I also think the FC>FD. It's almost like aesthetics are individual! The elements @GTSBoy likes about the FD and dislikes about the 180 are inverse in my eyes. I hate the rear end of the FD and it's weird tail lights that are bulbous and remind me of early hyundai excels. They are not striking, nor iconic, nor retro cool. The GTO has supercar proportions. I maintain these look much better in person (like the NSX) especially with nice wheels and suspension which is mandatory for all cars pretty much. Some (or all) of these you have to see in person to appreciate. You can't write a car off until you see one in the flesh IMO. Like most people we probably just like/dislike cars which represent certain eras of design or design styles in general. I also think the 60's Jag E type looks HORRIBLE, literally disgusting, and the 2000GT is nothing to write home about. FWIW I don't think the Dodge Viper Gen1's have aged very well either. You can probably see where I rate bubbly coupes like the FD. I know we're straying now but the C4 and C5 absolutely murder the Viper in the looks department as time goes on, for my eyes. Wouldn't surprise me if people who love the FD, also love the MX5, Dodge Viper, Jag E Type, etc etc.
    • I used to hate R31s, and any of the other Nissans that led up to it, and any of the Toyotas with similar styling, because of the boxiness. They were, and remain, childish, simplistic, and generally awful. I appreciate R31s a lot more now, but only the JDM 2 door. The ADM 4 door (and any other 4 door, even if they are unique compared to our local one) can eat a bowl of dicks. The Aussie R31 is also forever tarnished by their association with stereotypical bong clutching Aussie R31 owners of the 90s and early 2000s. I think the Nissans of the 70s (other than 120Y/180B/200B) are far superior looking to the 80s cars. The 240K era Skylines are boss. The same is broadly true of Toyotas. Hondas don't ever register in my thinking, from any era. Mitsus are all horrid shitboxen in any era, and so also don't register. Subarus are always awful, ditto. Daihatsus and Suzukis also don't generally register. They are all invisible. I think the SW20 MR2 looks fiddly. The 3000GT/GTO is like that but way worse. Too many silly plastic barnacles and fiddly gimmicks ruined what could have been a really nice base shape. Kinda-sorta looks like a big heavy ST165 Celica coupe (and I'm not sure if that's a good thing or a bad thing). I think the 180SX is dreadfully bland. It's not bad looking. But it has no excitement to it at all. It's just a liftback coupe thing with no interest in its lines, and bad graphical elements (ie wide expanses of taillight plastic on the rear garnish). The S13 Silvia is a little better - getting closer to R32 shapes. But still....bland. S14? Nope. Don't love it. S15...a little better. Probably a lot better, actually. Benefits from not being like a shrunk in the wash R34 (where the S13 was a shrunk in the wash R32 and the S14 looked like a Pulsar or something else from the stable on Nissan mid 90s horrors). The Z32 was hot as f**k when it came out but hasn't aged as well as the A80. Keep in mind that I think the R33 is the most disgusting looking thing - and out of all the previous cars mentioned is objectively closest to my precious R32. It's just....real bad, almost everywhere you look. And that is down to the majority of what was designed in the 90s being shit. All Nissans from that era look like shit. Most other brands ditto. In that context, the FD absolutely stands out as being by far the best looking car, for reasons already discussed. Going behind the aesthetics, the suspension alone makes it better than almost any other car.
    • If they just called it the "Mazda Tiffany", it would have been spot on.
    • Yup but for me its the HR ! Cut my teeth on the old holden 6s in the day ! And here's me thinking in the day it was also the 300ZX and the Mitsubishi GT3000 ! All, as well had good lines, but always seemed to need finishing off, style wise.
