R34 GTT
Rb25det NEO Stock engine
HyperGear high flowed Turbocharger
ID 1000cc injectors
Walbro 460L fuel pump
Power FC + Z32 AFM
Greedy Profect B EBC
600x300x81mm PWR Cooler kit
3inches turbo back exhaust
4inches intake pipe with Pod
Split fire coil packs
Turbosmart 45mm external gate welded on exhaust manifold.
At higher boost level we've reached 340rwkws before experiencing ignition break down.
https://www.youtube.com/watch?v=Mgz8Wzyc6X0&t=6s
Edited by hypergear
  • Like 1
  • 4 weeks later...
R34 GTT
HyperGear ATR45SS Turbocharger
ID 1000cc injectors
Walbro 525L fuel pump
Power FC + Z32 AFM
Car made 400rwkws @ 24psi, E85 fuel. Hitting 20psi by 4000RPM.
  • Like 2
  • 4 weeks later...
S1 rb25
Built motor
6boost
Precision 6062
Twin 45mm gates plumbed into exhaust
4inch turbo back exhaust
600x300x100 intercooler
1650cc injectors
Haltech platinum pro
United e85
Stopped at 29psi as we were worried about the headstuds giving way.
710hp @29psi
Sorry for the poor video quality
Edited by r33ryan
  • Like 7
R34 GTT
Rb25det NEO refreshed engine
HyperGear ATR45SAT Turbocharger
ID 1000cc injectors
Haltech ECU
600x300x100mm Cooler kit
3.5 inches turbo back exhaust
Car made 420rwkws @ 25psi, E85 fuel. Hitting 240rwkws / 20psi by 3800RPM.
  • Like 1
Rb25det s1 unopened
Haltech Platinum Pro plugin
Gtx3076r gen 2 twinscroll
6boost
Twin Turbosmart 50mm gates
Plazmaman plenum
1000cc Bosch injectors
Bunch of other stuff
376hp at 20psi on 98 - expected a little more
Soon to be tuned for e85
My old R33 after i sold it.
ATR45SS turbo
4" intake pipe
External gate on stock manifold
Z32 MAF
Trust return flow fmic
Splitfire coilpacks
Clean injection fuel rail
3" hks super drager exhaust
Standard cat
Z32 nistune ecu
98Ron
  • 4 weeks later...
Rb25det unopened engine
HyperGear High flowed R33 Turbocharger
ID 1000cc injectors
Haltech ECU
3inches intake pipe with Pod
Internally gated factory exhaust manifold.
Car made 342rwkws @ 20psi, E85 fuel.
  • Like 2
  • 4 weeks later...
I used to come into here to find what people had tried and what was needed to run to get 'x' power so might help some looking to push rb25 and a real world example
Comparison between old GTX3076 0.82 with spitfires and std CAS  vs GTX3582 Gen ll 0.82 with Audi R8 coils and new CAS
This is for circuit car  - anything else I think the (new or old) GTX 3076 is pretty solid for 450 to high 500hp's
Done on a roller :
Old GTX 3076 0.82 setup on 24.5 psi - 550hp and 620nm   - was awesome overall - good response - noses over at 7K
New GTX3582 gen ll 0.82   on 23 psi - 570hp
                                                 on 26 psi 663.5hp and 700nm - havent driven it yet but woke up with psi and wanted to keep making powas
Relevant things:
Rb25 built
Poncams
Audi R8 coils
New CAS
6 Boost
Bosch 1600 cc Injectiors
Plasmaman plenum
Koyo Rad
PWR 500 x 300 intercooler 2" piping
3" straight through exh
45 Ext gate to screamer
GTX3582 0.82 Gen ll
PPG 5 speed dog box
4.11 diff ratio
1495892058_DynoRb25Gtx3582genllvsgtx3076.thumb.jpg.03eaf21172dc6e4113edf368ec18e914.jpg
Edited by bcozican
  • Like 6
Got my car tuned finally by DVS JEZ after having some issues with "less competent" tuners in Canberra.  I know my setup is not ideal (return-flow) but was hesitant to spend money on restrictive parts if i needed to spend money first on fundamental running issues.
Setup is as follows:
R32 Nistune ECU
EFI solutions Top fuel rail kit,  stock FPR with Bosch 0 280 157 187 495cc Injectors
Bosch Z32 AFM
3" Turbo back (bellmouth, port matched) 3" 100 cel 4" body Venom cat, straight through mufflers
Hypergear G2 21U Highflow
Greddy Profec OLED EBC
Custom Hard 3" intake pipe joining to stock Airbox, Return Bov
Return flow AVO Turboworld intercooler
R32 10psi actuator pre-loaded 3mm
GTR BOV
NPC clutch
SPlitfire coilpacks
Standard Walbro 255 with the wiring mod.
Overall result is pretty good but quoted from Jez couldn't get more out of it "too prone to detonation", note the 230kw run was abandoned. so running 223Kw on 16psi
Now i know its running right i am looking to buy a new intercooler either HDI or Plazmaman and the 5" body 100cel 3" cat and then getting the tune tidied up a bit.
My initial goal was to make the most responsive setup compared to stock turbo running 98 and airbox (hate the sound of pod filter) hence g2 profile choice. Can see my old tune in second pic of stock turbo and breathing mods.
Tao what do you think of the result? Besides changing the above (intercooler and cat)  and staying on 98 and an airbox (happy to modify it), is there anything else i can do to increase response/boost response.
Kind regards
Patrick
  • Like 1
R32 Nistune ECU
Bosch Z32 AFM
GTR BOV
NPC clutch
SPlitfire coilpacks
Kind regards
Patrick
Sorry put the question on the wrong thread, posted on hypergears
  • 1 month later...
whats going on hoons? long time reader first time poster - here is a basic set up that has pulled in some decent rewards, got me a 2 mins at PI and a 1:47 at winton in full daily drive trim and horrible old clapped out semi slicks
highly recommend adaptronic, advice and turbos from Tao, tunes by chequered
donk: a not tired RB25 S2, 128,000 km, healthy comp, stock internals
hypergear something turbo G03 rings a bell
adaptronic
deuchwerks 550 side feeds
a shitty TURN FLOW
stock filter box with a K+N panel
a good greddy exhaust, was on it when i got the car, looks like a beauty (3 inch)
a f__king mad catch can rraaahahhhhh
260 kw at 16 psi, not pushing it
that is a good outcome folks
and if you are gonna persevere with a turnflow - make sure you have a real strong actuator spring
Edited by 12 second volvo
  • Like 1
  • 1 month later...
  • 3 weeks later...
R34 GTT
Rb25det NEO Stock Cams
Nitto Pistons and Rods. 9:1 CPR
ID 1500cc injectors
Power FC + Z32 AFM
Twin pulse manifold and twin 40mm gate. (Grey was single scroll manifold with single gate)
Car made 440rwkws @ 27psi, E85 fuel.
2 hours ago, hypergear said:
R34 GTT
ID 1500cc injectors
Power FC + Z32 AFM
What size of both exhaust housing?
  • 1 month later...
R34 GTT
HyperGear ATR43SS-2 Turbocharger
ID 1500cc injectors
Power FC + Z32 AFM
Car made 442rwkws @ 25psi, E85 fuel. With 280rwkws @ 4000RPM
16 hours ago, WR33KD said:
You need to adjust your dyno read out or are these super low torque?
Those torque figures are actually correct as it has been derived off the RPM.
Most dyno operators don't bother setting up the derived torque value and just output roller torque on dyno sheets hence it shows higher numbers.
Power (kW) = Torque (N.m) x Speed (RPM) / 9.5488
Ie
Torque (N.m) = Power (kW) * 9.5488 / Speed (RPM)
If you're reading wheel RPM instead of engine RPM your torque values will be higher.
    • Interesting.  Great info. thank you.  Give a few days to get that name plate.  I have a busy life most weeks.  I will be in touch.
    • Strange your posting about this being an issue. Move the harness or change your wheels or run more camber etc. Have the thing not touch the thing so it doesn't destroy the thing.  Short answer, no. Slightly longer answer, the factory fuel gauge is measuring resistance. You need to wire in the FPG fuel level sender into the original factory fuel level sender wiring.  I drew you a picture to explain this one The factory strainer is quite long, reaching down into the bottom of the tank. Safe bet your aftermarket fuel pump has a little baby sized strainer that probably doesn't even point down towards the bottom of the thank.  Solution, move the pump lower down in the tank, or fit a longer strainer, or do both. I did both, I've run my tank down to 5L remaining and the car still drove fine.
    • S2/3 GT-R is the same as S2 GTS-t The SRS airbags module in under the centre console. The S1/S1.5 GTS-t and S1 GT-R had the module built into the steering wheel. FWIW, I have a S3 GT-R wheel in my S2 GTS-t shit box. Same airbag plug, airbag light goes on then off, meaning all systems are go. S3 GT-R has red stitching, that's about it.
    • Dumb question, but why would it matter if the wheel came off a car with hicas or not?
    • Hey to anyone that reads this, long time lurker first time posting, sorry if it’s been answered before but I’ve been looking for nearly a year now for answers. ive got a 25det neo in an r32 that works awesome when it works (made 500whp on 21psi) but works 45% of the time, 1st issue there’s a harness that runs under the passengers side front fender that my tire keeps rubbing through and one wire seems to power the fuel pump even though I’ve done the relay “mod” some people like to call it, and when it does rub through it kills the car, yes next time I’m with the car I want to take the fender off and try tuck the harness well out of the way but I’d also like to try and by pass this mysterious wire as well lol, also wouldn’t mind getting power from the alternator as I’ve read it supplies the pump with 13v ? But no idea where to run the power wire too. 2nd issue, when replacing my fuel pump and fuel hanger I managed to break the factory fuel level sender leaving me with no fuel gauge, I’d like to buy the fpg fuel level sender for r32/s13 but the plug it comes with confuses me, I’ve got a detschwerks x1 fuel hanger which has light + pump - level + pump + and a ground, I’m no auto sparky but I’m wondering if I can cut the plug off the fuel level sender and wire the negative to the pump negative and wire the positive to the level positive to get a fuel gauge back ?🥴 3rd and final issue, the reason I want a fuel gauge is because whenever it’s below half a tank, it fuel starves like crazy and runs like a bag of shit even without doing a pull or sloshing the fuel round in the tank, I’d also like to fix this but have no idea what’s causing it, I’ve got a dw420 and a dead head fuel setup meaning the fuel is regulated before it gets to the engine, my only theory is that the return line is to close to the pickup on the pump and when it’s at half a tank the return line is causing the pump to cavitate enough to cause fuel pressure issues, that or the pump isn’t low enough in the tank which I would find strange considering I can’t find a single thing online about it, also if ya wondering how I figured out it happens at half a tank without a fuel gauge, I waited until it started happening and went and filled up and the car took exactly 30 litres every time I tested it, if ya managed to read through this mess I appreciate that and any recommendations , cheers
