Mainline Dyno 450 Kw on 98 Octane
This ER34GTT is running a RB25 with a nitto stroker 2.8 kit.
A Haltech Elite 2500
Just a quick comparison running V Cam Off and On
Boost duty was left the same.
Pump gas
450kw on 25psi with VCAM
and
400kw on 24psi without.
50KW gain!
Tuned by Jacky @ #sthitec #jtune_nz
Yelsha D Trigger Kit, YelshaD Billet Cam Covers, YelshaD Water Pump Blank off, YelshaD Alternator Kit, YelshaD Fuel Bulk Head
Edited by DCJ Panther
  • Like 2
  On 14/08/2021 at 2:46 AM, iruvyouskyrine said:
Do you mean VCT or V-Cam? I don't belive you can have V-Cam with billet cam covers
Expand
It’s VCT/RB25. It’s not a Subaru sprocket that vcam uses.
  • 1 month later...
Engine: RB25DET Neo with stock internals
Haltech Plug n Play ECU
HKS Airfilter, HKS Silent Hi-Power Exhaust Catback, GT28 Turbo, R8 Ignition Coils, Fuel Pump, Intercooler.
Rest is stock, including stock Catalysator and Intake (Street legal in switzerland)
Aprox. 320kw
  • Like 1
  • 1 month later...
R34 GTT
Rb25det NEO Stock Cams, factory engine
HyperGear ATR45SS-RB26 Turbocharger
ID 1500cc injectors
Twin Walbro 525L fuel pump
Adaptronic Plugin ECU
600x300x81mm PWR Cooler kit
3inches turbo back exhaust
4inches intake pipe with Pod
Split fire coil packs
T3 high mount with 50mm external gate
Car made 390rwkws @ 26psi, E85 fuel. 22psi @ 3500RPM.
  • 3 weeks later...
Hi, My car nissan 200sx s14
rb25det neo full stock engine
GTX3076 Gen1 Turbo
E5 Fuel Pump
Ecumaster classis ecu
985 cc bosch
oem ignition
1 Bar Boost
Mustang Dyno 330 WHP (this dyno is always low power 😎 )
100-200 km/h 1 bar 9.8 second
100-200 km/h 1.4 bar 7.53 second
car weight 1350 kilos
60.thumb.jpeg.2039761e3898398dc92d84c892a27614.jpeg64.thumb.jpeg.510396f9e9d2d24ef3c238f42d2fb4c2.jpegIMG_3155.thumb.PNG.bb4b73936863459addb239226a529d0e.PNG
Edited by webomur
  • 3 months later...
R33 gtst
Rb25det nitto I beam rods cp pistons, head studs main studs, completely stock head including cams
2x044 pumps   Garret gtx3076gen2 3" exhaust no cat power FC and z32 AFM tuned on e85
Main line hub dyno                  414kw @24psi                        348kw @20psi
Edited by Hpjunky
Miss spelling
  • Like 4
  • 2 months later...
Nissan R33 GTST Drift car
Forge bult Rb25det Neo engine
Stock head with upgraded valve springs
Nitto Pistons and Con-rods
HyperGear ATR43-SS3 Pro Externally gated turbocharger
6 boost manifold and twin Turbo smart 50mm gates
ID 1650cc injectors + Walbro 520 Fuel pump
Forward facing plenum
Front mount PWR intercooler kit
Fuel system maxed at 465rwkws @ 23psi, full boost by 4K, E85 fuel.
  • Like 2
  • 1 month later...
HyperGear ATR43-SS3ProR Externally gated turbocharger
Twicked this turbo alittle bit, Made same power, picked up another 500RPM of response and 100kws in mid range at same boost level or 23psi, still running out fuel even with an extra pump.  I think the original version of SS3Pro would peek 70kws more at full capacity.
  • Like 1
  • 5 weeks later...
R33 GTST
Rb25det NEO Stock Cams, built buttom end
HyperGear ATR45SS Turbocharger
ID 1500cc injectors
Link ECU
3.5 inches turbo back exhaust
Car made a super responsive 512rwkws plumbed back @ 32psi,  and 500rwkws externally gated @ 28psi, full boost @ 4000RPM
Edited by hypergear
  • Like 5
  On 16/06/2020 at 12:39 AM, Dose Pipe Sutututu said:
Time for an update to the shit box, this time with bigger and badder dose pipe for you dose bitches. Nearly 3 years in the making too :D
407kW @ 2bar -> 1.8bar  on E85. Mainline AWD dyno, with 16kph/sec ramp rate.
Mods:
  • Garrett GTX3576R Gen 2
  • Garrett T3 1.01 divided rear housing
  • Turbosmart Gen V 50mm
  • Sinco T3 twinscroll, single gate manifold (pulses split to the gate seat)
  • 3.5" Turbo back with 5" body Venom Cat, 2x Mufflers
  • Generic built RB25DET NEO motor
  • Spool billet oil pump gears
  • Tomei 260/9.15 Poncams
  • 80lb Valve Springs & Ti Retainers by Performance Springs
  • HDi Hybrid 76mm eBay FMIC (holding back the power)
With high IATs air density is dropping, thus boost is bleeding off as well with small DC corrections on the boost DC table. I did order a Plazmaman Pro cooler but it didn't arrive on time. IAT peaked at 57 degrees C in a dyno room with an ambient temp of 19 degrees C. From the data, reducing the IAT will improve the boost control up top, get more air into the motor and will yield the results I'm after.
Once the FMIC comes, I'll be back for round 2.
Special Thanks to:
  • Alex at Birrong Automotive for allowing me to use his dyno
  • Adam at Weldspeed for the fabrication work
  • Yez Racing for supplying most of the parts
Data, etc. available in my build thread here:
Sorry for the lack of derived RPM, I forgot to set it up, in the Analyse screen it shows you true RPM vs. Power vs. Torque.
Log during run:
IAT post run:
Expand
Time for an update, same turbo but refreshed motor now with 437.9kW at 1.7bar boost dropping down to 1.5bar towards the redline. Looks like I've maxed out the compressor at this stage. I believe there are some improvements to be had such as venting the gate to atmosphere and deleting the cat.
Will be back to get the closed loop boost control dialled in when I have time. Was a pretty surreal experiencing for me as I've never tuned anything this powerful nor anything that revs this high! Alex said I could safely bring the rev limiter to 8600rpm if I wanted to (which I did lol).
Mods:
  • 3.5" Turbo back with 5" body Venom 100 Cell Cat, 2x Mufflers, Gate plumbed back
  • Generic built RB25DET NEO motor (CP Pistons, Manley Rods, Nitto rings, ACL bearings, ARP dis dat, etc.)
  • Spool billet oil pump gears Nitto Oil Pump
  • Tomei 260/9.15 Poncams Kelford 264/272 244-B
  • HDi Hybrid 76mm eBay FMIC Plazmaman 76mm Pro Series
  • Plazmaman Intake Manifold
  • ATi Balancer
Below is the log (no idea why SAU makes the thumbnails so damn small now. Ignore the oil pressure, it's reading wrong. I suspect the sensor has the right part number printed on it but it's actually a 5 bar sensor (not 10 bar).
Here's a video my mate recorded of me tuning, you can see I'm constantly looking at Alex to see if I need to abort the run. Previously there was a misfire event that sounded like engine knock from where he was standing. I took out the plugs then gapped them down to 0.4mm and it sure did the trick!
  • Like 5
  • 3 weeks later...
R33 GTST
Rb25det Block + Rb26 Crank
Arias 86.5mm Pistons
Eagle H beam rods
ARP 2000 Main studs
Half inch ARP head stud conversion
N1 Nissan Oil pump with Spool gears
Reconditioned head with Kelford Valve springs
1650cc Fuel Injectors
520L fuel pump
Haltech ECU
High mount exhaust manifold
HyperGear ATR43SS-3 Turbocharger
50mm external gate
Tuned at Chequeredtuning
Final result of a responsive 455rwkws @ 26psi maxing out onboard map sensor
294018895_376109891127593_5354837264242904396_n.thumb.jpg.403c055316eaf4d452903284ab6d68d3.jpg
  • Like 1
  • 1 month later...
R33 Rb25det 2.5L engine
CP Pistons
Spool I beams
Stock crankshaft
Spline drive oil pump with billet gears
Arp2000 headstuds
Athena headgasket
Performance valve springs
Stock cams
2400cc Fuel Injectors
2x 520L fuel pump
Rb26 inlet manifold and itbs
Crg twin scroll t4 manifold single 50mm turbosmart gate
Haltech ECU
HyperGear ATR45SS2-RB26 Turbocharger in T4 .82 rear
All work done and tuned by CPG
Final result of 635rwkws / 754rwkws @ 37psi with Nos.
E85 fuel
  • Like 3
  • 2 months later...
R33 GTST Series 1.5
Rb25det Engine:
CP pistons
Spool Con-rods
Kelford 262 / 272 Cams
APR head studs
ID 1650 injectors
2x Walbro 460L Pump
GTR Coilpack upgrade
HyperGear ATR43SS2 Turbocharger
6 boost high mount manifold
Greddy Forward facing plenum with 3 inches throttle body
PWR 600x300x81mm intercooler
3.5 inches stainless turbo back exhaust
50mm Turbosmart gate plumbed back
Haltech Plug-in ECU
Tuned at Chequered tuning
Still have boost control issues to sort, making 400rwkws @ 20psi so far.
enginebay2.thumb.jpg.4861a62f96b3706464980df9df4e26f9.jpgcarondyno.thumb.jpg.5438f612ce6518ab2e6ac613a8b56716.jpg400rwkw.thumb.jpg.34fb54b6fa78dfbfd057b5edd665d721.jpgboost.thumb.jpg.221d7f56a9e8c8b1d57c6a14c9b2604b.jpg
Edited by hypergear
  • Like 1
  • 3 weeks later...
R34 GTT
Factory Rb25det Neo Engine:
ID 1000 injectors
Walbro 460L Pump
HyperGear ATR43SS2 internally gated Turbocharger (2022 June release)
Plazamaman Forward facing plenum
Plazamaman 600x300x76mm intercooler
3 inches stainless turbo back exhaust
Link ECU
Tuned at Chequered tuning Work done at CPG.
Final result of a responsive 346rwkws @ 22psi on E85 fuel so far. Boost held perfectly till red line with plenty of power throughout rev range
318599580_5791546430965619_2613132159764501821_n.thumb.jpg.fd9638a7f317905167e11e9c0b88caaa.jpg
317999160_1200705453852754_1318106964589292279_n.thumb.jpg.93e494986a860f45c8ba1a86e97c2e55.jpg
318292315_1806411269715570_602202984049436119_n.thumb.jpg.38ebdd5d3f31fe542aa4ebcfb8f95c4d.jpg
  • Like 3
  • 2 months later...
R32 GTST Manual
Rb25det Engine
Cp pistons
Spool rods
Cam tech 264 cams. 0 , 0 on Cams gears, No VCT
Hypergear ATR43SS3 turbocharger in T3 .63 rear
Freedy intake
6 Boost T3 Single entry exhaust manifold
Valve springs
1650cc injector
Haltech ecu
389rwkws @ 20psi, Full boost @ 4000RPM.
Pump 98 / Ron 93 fuel. NO E85 this time.
331649005_2126697534194726_5116472742497761640_n.thumb.jpg.09f86193a5cbb597d074439c059549a0.jpg
331812784_1206937897375212_6998443198651292934_n.thumb.jpg.261aac1f59dc4c65e26b5a34993c3088.jpg
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
