I've got a Blitz BOV with the adaptor just sitting here so I've decided to install in my car but i'm not sure where the hose coming out of the bov goes and what to do with the original bov.
so what i know is that i'll have to take out the pipe coming from the intercooler and chuck the adaptor with bov instead.
https://www.sau.com.au/forums/topic/5585-blitz-bov/
hey
iv got the exact same bov, but due to my fmic i could no longer use that pipe (new piping all round)
so what iv done it taken off the blitz bov from that pipe/kit, and also taken off the factory bov.
made an adaptor that: on one side would fit on the factory flange, and on the other side would fit the blitz bov (if i made myself clear enough)
so, now my blitz sits in the factory location neatly
id take a photo of it if i had a digi-camer (sorry)
also, that 'hose' is the vaccume line that should be connected on the throttle body. if u look at the factory bov, youll see where it goes, u should use the same line of the bov to function properly
https://www.sau.com.au/forums/topic/5585-blitz-bov/#findComment-84588
yeah, take the hose off the factory on and hook it up to the blitz (obviously wont reach, so just get a new hose)
for bext results, take off the factory bov and place a plate inbetween it so as to block it off
or
u can take off the factory one all together and block it off with a plate, its up to you
when i had the standard piping i kept the factory bov in place so as when police happen to open up the bonnet, theyd be nun the wiser cos the blitz was hidden away under the air intake snorkel :(
https://www.sau.com.au/forums/topic/5585-blitz-bov/#findComment-84591
Originally posted by skyline33
here is a photo of what i've got
Hey Dude..
Where you get this picture from? It lookslike my wood floor with my pre-owned Blitz?
I can show you how to connect it to the presure ture behind the passenger side head light without back to intak..I will take some picture when I get home..
https://www.sau.com.au/forums/topic/5585-blitz-bov/#findComment-84774
i used to have one on my current car from japan and it was working fine, then i took it off and chucked it on another car and it was stalling left right and center.
some close calls when taking corners, all of sudden its just stalls and you lose power steering and braking (not recommended)
https://www.sau.com.au/forums/topic/5585-blitz-bov/#findComment-85436
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
