Hi
I have an r33 gts-t. My current mods are:
3" dump+front pipe
4" hks exhaust
hi flow cat
bleed valve @10psi
hybrid fmic
pod with cai
apexi power fc
i have not got the power fc tuned yet i was just wondering what other mods
should i do before i get it tuned. do i need to get a new fuel pump or regulator? or maybe even cam gears would this make any difference. I'm aiming for anything over 200kw at tha hubs. i don't want to upgrade turbo atm. cheers
https://www.sau.com.au/forums/topic/55872-what-mods-should-i-do/
I think a better fuel pump is a good idea, aftermarket adj. fuel reg will enable you to get a little more out of your stock injectors.
But if your only running 10psi in a standard turbo you could get away with stock pump& reg, depends on how much further you want to go? after the fuel supply is up to scratch.....hi-flow or bigger turbo? more boost.....then bigger injectors....by this time no doubt a ceramic button/heavy duty clutch will be needed.....
skys the limit.....thats the best part :D
good luck anyway :D
hot.. HOT girlfriend in the passenger seat.
extra ba-zillion kilowatts at street lights.
... (sorry I've always thought it was true and I've always wanted to say it).
Also - have you thought about suspension mods? I know it's not an engine mod but it certainly is a performance mod (ie. go faster) :D
Also - have you thought about suspension mods? I know it's not an engine mod but it certainly is a performance mod (ie. go faster)  :)
ar yeah i also have tein suspension fitted nice firm base to work with that hot girlfriend in the passanger seat. one step ahead of ya's
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
    • Yeah, my offer was more to show exactly how rough and ready the rig can be and still be useful. Youtube vids will definitely show cleaner setups. Same concept though.
    • I would guess the seal has gone down at the speedo drive and gearbox oil has crept up the drive cable sheath and fouled the speedo head.
    • Any updates on this? Although not a stroker, nor built especially loose, my car has the exact same symptoms. Although I feel they were not there to begin with. Since rebuild with forged parts I have done about 40k kms and it feels like during the last 15k or so, the oil consumption has gotten progressively worse.  Compression test showed - what I thought at least - similar 10-10.5bars in each hole without oil. I have not yet done blowby test though, due to limited garage access. #2 plug is the looks the most foul and that was the one with 10bars. Nothing in the breather tank. I only recently disabled PCV and left only the hoses running from the valve cover via smallish tank to turbo intake pipe there and did some mildish 2nd gear pulls so the car was definitely on boost (1.4bar or so). Removed a hose from the tank and it was basically dry - meaning, the wipe I used had basically no oil on it. Last time I checked, the turbo and IC piping seemed dry as well (will have to see about that again after those pulls). For the past year and a half though, the car has been driven like a granny would for 99.99% of the time, since it mainly serves the purpose of carrying the family around nowadays. A lot of slow, stop and go city driving and most of the trips it barely sees any boost, but gets up to temp properly every time. Although there can be weeks it is not started at all. The car does not smoke, or at least not that I can see. (CAT is in place though). There is slight visible sweating at the Ex cam cover seal and I recently tightened the oil cooler lines as there was some mist on them too. It runs and idles extremely nicely and feels all around healthy. Like TurboTapin, I too am suspicious of my turbo. I have had IC pipes pop out from 1.6-2bars of boost a half a dozen times during the years. The turbo is a HX35/40 hybrid. So, a very similar mystery. Around 1500kms and a litre of oil surely cannot disappear to thin air. Apologies for the wall of text, not sure if any of the above is useful for best guesses/things to check next.
