I have just had a Viper alarm fitted to my C34. It was reported that the wiring was 'the same as an R33' . So based on that it shouldn't be too hard to determine the factory wiring for an alarm.
It looks like the Series 1 cars really are a '33.5' setup - not quite R33, not quite R34.
https://www.sau.com.au/forums/topic/55875-wiring-diagrams/#findComment-1090526
can anyone confirm if the series one and series two ecu plugs are the same? just not sure due to different trans and change to neo engine
ECU plugs are definitely different, according to the list I have cars later than 9/98 have the new type plug, and this is listed as the same as the R34 GT/GTT plug so that must be the NEO/series 2 changeover date. Note that all years of the 260RS and GTR use the earlier type plug (same as all R32/33's).
The doco I've got showing the different plug types came from this forum, it is a doco from Blitz.
https://www.sau.com.au/forums/topic/55875-wiring-diagrams/#findComment-1096626
yeah i thought so
so what does the series one plug match up with? is it the same as a skyline r33?
Nope, nothing like a R33.. :D
In a Apexi SAFC2 wiring manual diagram that I've got, it lists (and pictures) the R34 rb25det 98.5 to 01.5 year/month, to be the same wiring diagram and plug as the Stagea rb25det 96.8 to 01.10 year month.
So I'm more confused now... :D
J
https://www.sau.com.au/forums/topic/55875-wiring-diagrams/#findComment-1097079
Nope, nothing like a R33..  :)
So I'm more confused now...  :)
J
Err, I have Stagea ECU connector for cars 10/96 to 8/98 (series 1 I guess) listed as the same as the R33 (and R32 for that matter)?
So it looks fairly straightforward to me, Stagea series 1 = R33/32, series 2 = R34, with the exception of the 260RS = GTR.
Bah, tried uploading the PDF doco showing this but it is too large (320kb). Will try to find where I got it from....
https://www.sau.com.au/forums/topic/55875-wiring-diagrams/#findComment-1098019
Maybe there was too different types. Not sure why they would do it though.
I had my car in at the work shop about 6 weeks ago to get a piggyback installed. I gave them a picture and pin out for a R33 ecu thinking they would be the same. They rang me a few hours later to tell me that the ECU in my car was nothing like the picture I'd given them and they couldn't work out what it was !
Hence why I did a bit of research, and it seemed that it was the same as the R34's.
I think I REALLY confused now !
J
https://www.sau.com.au/forums/topic/55875-wiring-diagrams/#findComment-1098040
Ok, here is the link to the ECU connector diagrams:
http://www.blitz.co.jp/Operation-manual/el...ermeter-ecu.pdf
Perhaps post up which model of Stagea you have (S1/S2, neo, non-neo) and which ECU connector (BN-1, BN-6) you have to verify or otherwise the info in this doco!
https://www.sau.com.au/forums/topic/55875-wiring-diagrams/#findComment-1098496
yeah that is the pdf i found a while ago too and posted up a question along the same lines
according to that the connector is the same but that does not mean the wiring is the same though.
:confused:
Ahh, righto, thought it was one of you Stagea types who found it originally.
Good point re the wiring being different on the same connector...!
https://www.sau.com.au/forums/topic/55875-wiring-diagrams/#findComment-1099657
  • 4 years later...
