If they are HKS, they would likely have HKS stamped or marked somewhere on them (as nothing HKS leaves unmarked!). If they are garret they will be plain. My 2530 was second hand also and came with no actuator. I bought a garret one, and was told that its the exact same unit as the HKS one minus the HKS name on it.
regardless of brand, unless they are factory GTR actuators, they should be rated higher than stock. If you really wanted to you could test them if you have an air compressor, some boost signal or rubber hose, a couple of fittings, and a boost/pressure guage. Plumb it up correctly and progressivly squeeze the air gun trigger till the actuator rod extends, note the pressure on the guage at this point.
Alternatively just stick em on the car and find out.
