Hi guys,
Yesterday I was changing illumination globes as half of them had blown, so carefully pulled out dash and cluster.
But when I next drove it I had no power steering or speedo (everything else on cluster works other then k counter and speed.)
I was very carefull and plugded it all back in and even double checked.
Checked all fuses that I could find but all fine.
please help if you can.
Thanks
https://www.sau.com.au/forums/topic/55994-r32-sedan-no-speedo/
do the R32's use electric speedo's or was there a big cable thing going into the back of the cluster.....sounds like something is not plugged in correctly.....you are simply going to have to remove the cluster again and check everythin you touched the first time around.
Are you sure you clipped the speedo drive into the back of the speedo. You have to engage the square centre properly or it will pop out.
I think this is the only thing that would stop the speedo from working.
I'm not sure how this would affect the power steering but maybe it requires some sort of speed sensing to operate properly.
i got the same prob right now
took it to my auto electrician and told me that it is cable driven and that the cable and sensors near the gearbox seem to be fine, he said the problem could be within the cluster itself.
I havn't had time to get it checked out, so i would be interested to see how you fixed it.
Yeah, look for the lil spring that goes wid the cable and the speedo cluster when u connect the 2 togetha... if it's not all connected u won't have a speedo, odometer or power steering (trust me :()...
There's a lil white thing that goes between the cluster and the cable and there's a spring in it... make sure that springs there and that it's all plugged in right (it's a bitch to do - took me bout 10 goes! lol!) and then bob's your uncle!
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
