haha u noticed trhe spoiler(s). i was going for 1 spoiler wid 2 wings. :looney: the front bar is from one of the SAU member's 34' GTR. and uh the nismo sticker :Oops: . that is my gf's contribution to the car. bleh. ! thanks for the feedbak u peeps. i will try to do more for all to see. yet again!
