Got two new tryes and an alignment. Alignment my ass....the car's pulling to the left. The guy reckons they can't fix it because it's the way the japanese cars are made (their roads tilt in right, ours tilt out left)...but it wasnt doing it before i got the new tyres.
Any Ideas???
the hicas wont automatically self align....it's just a steering rack like the front, so to do a 4 wheel alignment on it should be the same as any other car. I did the alignment on my car same as i would any other 4 wheel adjustable and it drives fine. toed the rears in 1 and same for the front.
you should be able to let the steering wheel go and the car generaly stay driving straight, depending on the road it may vere (very slightly) in accordance to the camber of the road, but on a highway should go straight.
I dare say wherever you took your car just couldnt be bothered fixing it cause the story given to you shounds like a complete crock
:D
Berin
Any Ideas???
:wassup: BS :wassup:
Jap cars are right hand drive same as ours. Gutters are on the left, not in the middle of the road. The road cambers to the left so that the water runs into the gutters. Maybe its because they are in the northern hemisphere and the water spins anti clockwise going down the drain. Or is it clockwise :)
PS; find a decent suspension shop and get the caster (front only) and camber + toe checked on all 4 wheels. New tyres show up any small differences, older tyres can cover them up as they wear.
Any Ideas???
Let me guess, you went in for the free wheel balance and they told you "those tyres wont take a balance" so you got four new ones and a bodgie wheel allingment to go with. Anyway, as the people above have suggested that is an absolute load of sh1t. Try "spinning wheel tyres" in sydney (if you're in sydney that is) they are quite good. edit: D'oh, just saw that you're in perth, forget SWT then!
Richard
Hey guys
I just got my steering rack changed and the dorky mechanic forgot I got HICAS on the car so he just stick the rack back into the car without making sure the steering is as it was before.
The steering is now at 2 o'clock when the car is going straight,HICAS light goes off the moment the ignition is turn on.
My question is if I were to get it aligned now do I need to pay attention to anything in particular? or a normal alignment job is sufficient? Please help
devo, take it back and get him to pull the steering column from the rack and align it properly, and don't pay him cos he didn't do the job right the first time.
SK as always is correct.
Richard has obviously seen the dodgy buggers at work. I went in to get a quick balance before the last track day at PI and Beau's (the big blue place that's everywhere) tried the same thing...'..but the tread's too thin now (40%) and it will go out of balance at high speed.' Me - 'Have you ever driven on a race track at over 240kmh?' Beau's - 'No, never been on a race track.'
Get the alignment specs from Whitelines website and take them for your alignment so the idiots don't screw it up again.
  • 4 weeks later...
Richard
It was a hook up with cost price for the tyres and yeah, free alignment and balance. They WERE supposed to look after me. The man 2nd in charge dealt with me and when he found out what the manager quoted me, he was not happy...so i reckon it was a bit of a payback and the alignment wasnt done at all. It was beaurepairs in freo - so stay away.
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
