Pentae, these are the guys recommended by Prestige - Motorguard, Eagle Farm - 07 3868 4910 or another: Recreatiopnal Vehicles, Ernest - 5564 6177. I would have used them myself except I'm doing it down the coast.
You can only ring them and ask some questions.
Thanks predator.
I have sourced another mechanic to do the work for me. The reason I didn't go to him first was because he quoted me too high, but after letting him know that I can source the parts required myself he was reasonable with the counter quote.
I've used this guy before, I trust his workmanship, and he's almost in the CBD. He said that I was welcome to look over the car while it's up on the hoist to get a better view of the vehicle.
I will keep this thread posted on the outcome, hopefully within a fortnight.
Another good one is Wally from P&M motor body repairers at Capalaba. (3390 3999)
He might be getting 34 and 35 compliance within the next 6 months. He's got a 35 waiting in Japan to come over and he goes there every few weeks to buy more stuff.
He owns P&M and owns Cresta Australia(import spare parts supplier).
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
