Hi all
I was think of changing my S14 diff to a non V-spec R33 GTR diff. Similar to S15 i think but with shorter final drive.
Can any1 shed any light on wheather this is a straight swap or there is a lot of custom work need??? Any1 else done this??
What about non V-spec R34 GTR??
Cheers
https://www.sau.com.au/forums/topic/56104-r33-gtr-diff-into-s14/
Well the R33 is a 4.111 which would be good, the R34 has a 3.545 so you probably wouldn't really want to use that. The non-V-Spec diff is pretty tight, only stock diff I have ever heard skipping the tyres when you are parking. Very noice.
In one of the early issues of Speed magazine there is a S14 with an R33 GT-R diff in it and they seemed to think it went in fairly easily.
We put a 32 GTR diff, driveshafts, hubs and brakes on a S14 cause we bought a rear cradle dirt cheap. Don't know how easy it would be without the driveshafts etc as the GTR items are quite chunky compared to the stock S14 items.
Yes and then you need to use GTR rear suspension.. hassle
not at all.... the car still uses the S14a rear cradle. Sure, it required 2 mounts be put on the cradle to suit the GTR diff, but apart form that it all bolted straight in :D
if your wanting to swap the entire diff over, housing and all, you will need the drive shafts and rear hubs as the spline on the GTR drive shaft is slightly different to that of the S14 hub..... you will also need to ad some mounting points from the GTR cradle to the S14 cradle.
Just to add to this thread with Some R33 info. I spoke to a workshop that has tried and the R33GTR Diff will not fit the R33 GTS25t due to the tailshaft flange being different. It wasn't clear if the mountings for the diff were different but at the least a tailshaft mod would be required.
sorry mate, no pics as the car didnt make the hoist..... i did nelgect to mention that the tail shaft will definitely need to be modded as the GTR has a CV joint assembly as the rear universal joint, not a cross yolk like the GTST....
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
    • Great if: 1. You had all of the money for everything else that is required  2. Lived in a country where you could actually do this and drive it legally on the road Sadly, neither applies to me As for the turbo, I am having second thoughts, mainly for engineering/registration legality reasons and insurance  Not saying I've finished doing stupid things that I probably should do to the MX5, but boost, and V8 engine swaps isn't on the cards Strange, but true
    • I like this page, better than that silly turbo kit   https://v8roadsters.com/product-category/engine-conversions/engine-conversion-lsx/engine-conversion-lsx-nc/
    • That would be my Shoei helmet
    • Yes shipping here can be a pain, was about to purchase timing belt replacement kit, but it tends to get expensive due to shipping (and customs if importing from non-EU which the UK now falls under).
