I have never seen it, BUT the S15 fronts are not a simple bolt on addition to the S13's so therefore, don't expect them to go on without modification onto cefiro or laurel.
However with the kits available for S13's i would not imagine it would be too difficult. Would look a bit screwed up in my opinion though.
https://www.sau.com.au/forums/topic/56130-ichigo-cefiro/#findComment-1089402
haha well its got some skyline bits, and its got some s13 bits... and maybe more :) *oooh the suspense*
i wouldn't say bolted... lol you should check out some of the conversion jobs, shit like held on by an aluminium bracket that you can bend by hand n stuff. Then there's the bog jobs... thems real fun.
https://www.sau.com.au/forums/topic/56130-ichigo-cefiro/#findComment-1089427
Actually the kits for the S13 and RPS13 isnt that difficult.
Ive seen the kit for it and its easy to put together... i was going to get one for my mates RPS13 for 1800 including the lights, flared guards and vertex bar.
https://www.sau.com.au/forums/topic/56130-ichigo-cefiro/#findComment-1089546
isn't she purrrdy? we found her in the scrap parts section of yahoo auctions, checked the VIN, it was a 1989, only problem was that the engine was siezed, so we organised it to be trucked to the port and loaded. couldn't make up some ramps coz it was too low n stuff so had to send the mechanic out to mess with it.
Interior is clean as, with custom gauge install (not usual caveman style drill holes everywhere and poke shit in) in the centre console etc.
cost next to nothing cos it was a part taking car :)
https://www.sau.com.au/forums/topic/56130-ichigo-cefiro/#findComment-1089950
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
