alot of bikes cant run optimax because the engines dont run hot enough to burn the aditives.
i dont mind either i use optimax in the mx6 always have, i have run both in it and always ran better on optimax.
where ive only ever run Ultimate in the GTR.
just personal choice and some cars may like it some might not.
optimax cant be that bad the v8 super cars use it and there not exactly slow or stock.
https://www.sau.com.au/forums/topic/56172-optimax/#findComment-1090878
BP Ultimate is my fuel of choice! I have heard of people having serious engine problems with Optimax. One guy in particular was going to take Shell to court because he had proof that the Optimax he got from Braddon caused his engine to fail on his Lancer GSR.
Personally I ran Optimax in my R33 for a couple of years without any problems. I guess when you find something that works, stick with it!
https://www.sau.com.au/forums/topic/56172-optimax/#findComment-1090995
The whole country has run out of LRP. i was about to start restoring my old HG V8 Kingswood and now i find out they don't even make fuel for it anymore... have to get the valve seats hardened or something... or just chuck an RB in there
https://www.sau.com.au/forums/topic/56172-optimax/#findComment-1091064
having used both optimax and ultimate, I only use ultimate @ manaka/kingston, my girl doesnt splutter or ping as much.
Terminal: in the same boat as you with the LRP for the old v8 wb holden ute, but have been advised not to use the LRP as it can cause damage. So now she gets filled up normal unleaded and put a syringe of lead replacement fluid with every 50 litres of fuel, costs about $3.00 per syringe.
https://www.sau.com.au/forums/topic/56172-optimax/#findComment-1091119
lrp is pretty much gone the g/f has to use it in her honda and she told me that shell and woolworths in tuggers dont have it any more and erindale has stopped as well. She got some additive like u described skylinegal which she puts a small bottle into per 45 or 50l tank meant to be no different
https://www.sau.com.au/forums/topic/56172-optimax/#findComment-1091180
I hope that with the lack of optimax we aren't going to run out of ultimate too???
WTF am I supposed to run my car on???
Dunno but mine will do three hectares on a thimble of kerosene :P
On that note, someone mentioned V8 supercars run on Optimax. That they do (the color of the fuel they pump in though doesnt look the same as Optimax) but anyway, the V8's would be tuned to make the best of the fuel they do use. For a street car, it doesnt matter as much as it will compensate for good/bad fuel by adjusting ignition timing.
Reasons my crap runs car on Optimax is it was tuned on Ultimate, and in my car you can add more ignition timing using Ultimate than you can Optimax. That explains why my car pisses around and doesnt run properly when I use anything but Ultimate and why I dislike Optimax :D
https://www.sau.com.au/forums/topic/56172-optimax/#findComment-1091233
The v8 supercars use optimax???? I find that damn hard to believe.
yep offical fuel for v8 super cars.
hey you can even tell when there filling them cause optimax is that dank yellow colour and you can see it going through the hoses. no there fuel is that colour.
most hi oct fuels are clear exept some av gas, airports add colour to the fuel so if they catch it being illegally used they know where it came from.
https://www.sau.com.au/forums/topic/56172-optimax/#findComment-1091519
    • Apexi SAFC - AFC 1st Generation Rare Old School JDM As you can see it all lights up in the photos and is in 100% working condition. Has been kept in storage and boxed for years there won’t be to many like this if any! Especially with all original packaging and manual. price:$650   APEXi SAFC 2  In Complete Working Condition Refer To Photos and view the video provided.  Price:$500   Located Melbourne - Australia Wide Postage Available At Buyers Expense  IMG_6981.mov
    • wow so i just logged back in after buying the 33 and joining SAU, And I've got all a whole bunch of you wanting to know more, well unfortunately it still doesn't run i was hoping it was seized from a snapped timing belt as i turned it over by hand and it was fine and then it did a few revolutions and jammed solid when i was running it with the key, so the timing belt is mint, I've also found a lot of the parts I'm removing have already got bolts undone or not quiet tight enough to be unsuspicious. so the plan is to find a running RB30 block and chuck my head on it.  I have a habit of buying stuff I don't need or require so for my none running engine i have a forward facing plenum , Apexi power fc, 40mm Turbosmart wastegate, And for the car its self coilovers ,low seat rails and BRZ seats (black seats with red stitching i already had these and they are ADR Approved and allow rear passengers access)
    • I took apart the dash and found this strange 2 pin connector. it dosen't seem like its factory or oem, any clue on why someone would add it and where it might have been connected too?
    • Not mention a SS2 especially with that rear oddly small rear housing. I feel the Facebook mechanics and experts has led OP in the wrong direction.
    • Won't get near 400kw, pump and injectors nowhere big enough. Bin the manifold and get off the shelf and a modern ECU.
