Need some help.
Who in West Perth minds dropping the $15 to Greg for the caps on Friday night. I have a work dinner I can't get out of.
Speaking of West Perth whos was the Grey GTS on Friday lunch giving it some off the freeway up hay street and onto parliment street.
And if anyone wants to organise a skyline australia west perth lunch gimme a yell and I'll organise it.:(
https://www.sau.com.au/forums/topic/5619-who-in-west-perth/
Yeh im in South perth now but used to be in west perth.
We could all meet up one day for lunch i dunno.... somewhere not too expensive ahhh.... that little noodle place next to ANZ maybe.
Could drop in on ya on thurs if no1 else is willing
https://www.sau.com.au/forums/topic/5619-who-in-west-perth/#findComment-84958
Ummm Ok to be honest if my FMIC goes on this week i will be in the cruise... will know by late wednesday.... if i go on the cruise then no worries dude i will give em the $15 :-)
I think that is an excellent idea for all us that are in West Perth! all you other guys up for it? Could meet at West Perth food hall or sumfin??
https://www.sau.com.au/forums/topic/5619-who-in-west-perth/#findComment-84961
Yes that place is the best!! :uh-huh: It is called NOODLE INN! HUGE meals for only $6 and tastes sensational... some of us from work go there quite a lot! but a booking is essential as due to the good wuality and cheap price everyone goes there!!!
https://www.sau.com.au/forums/topic/5619-who-in-west-perth/#findComment-84964
Mine is a silver GTST, found 'giving it some' up that road everyday.
Lunch time for West Perth liners sounds like a plan. How many of us are there?
https://www.sau.com.au/forums/topic/5619-who-in-west-perth/#findComment-84986
*PUTS HIS HAND HALF WAY* coulda been me if it was a R32 GTS-t.. went to NB for some pizza friday lunch and came back down Hay Street up to Outram and was fanging it a bit.. but didnt go up parliament.. *shrug*
lunch sounds good.
Shaun
https://www.sau.com.au/forums/topic/5619-who-in-west-perth/#findComment-85007
I work in West Perth too.... But I also can't make it to this cruise due to a "work dinner" ...... I would like to meet some of you in person ( I have only been on two cruises and therefore only know very few people in person )
Brett
https://www.sau.com.au/forums/topic/5619-who-in-west-perth/#findComment-85443
Hmm, think u might have the wrong thread here buddy:)
We were talkin about "lunch" and no cruz involved.
U could prolly call walkin a cruz but im more of a lumber man myself *thud thud thud*
So did we make a decision on the day? how about friday at 12:15 cause my boss will be interstate so i can get a little tanked b4 i go back to work.:Party:
https://www.sau.com.au/forums/topic/5619-who-in-west-perth/#findComment-85483
Haha Boostzor....
What I was getting at was that I wouldnt mind having lunch as a way of meeting you guys!!!!! I havent met many of you guys in the past and I cant make the cruise this week so the lunch is my way of saying hi!!!!
Actually I beleive you were about the only person I spoke to at my last cruise.... If you remember it was at the start of the cruise at the OMNI building that night it got rained out really badly... We went up the coast then back down the freeway.... then we lost everyone because we didnt have a map :uh-huh:
I had the black R33.....anyways ..... I still look forward to the next cruise that I can make it too as well....
Cheers
Brett
https://www.sau.com.au/forums/topic/5619-who-in-west-perth/#findComment-86493
me got a thunder grey gts-t, r33. i can't remember coming off the freeway at lunch time but if it was the morning it was def me. were you the guy on the footpath opposite with a smile yee face, puckish.. just had my rig boosted the niote b4, so i thought i'd drift it around the corner. not much drift but all fun the same.
will be attneding the lunch on wednesday, my name is Rhys...pronounced reece..
catch up with you then..
https://www.sau.com.au/forums/topic/5619-who-in-west-perth/#findComment-87247
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
