Hey guys just bought my bodykit and wondering if anoyone knows a good place to get it fitted and sprayed? It needs a little bit of prep work.
Need somewhere that does a reasonable job for an good price. I know that you get what you pay for.... but still.... :)
https://www.sau.com.au/forums/topic/56196-paintshops/
yep its procoat ... if you're after something really cheap ... but isn't oo bad ... then he is good ... this is how cheap he is ... mind you i've used him a few times myself and plus i've referred alot of people to him so he gives me mates rates i guess ...
but anyways i cracked my front bumper ... not a small crack ... but a big one ... fixed it .. painted ... paint wasn't too bad either, fitted again, the fitting wasn't too bad, wasnt' that good either, if there was one thing that wasn't good about his work its the fitting, but anyways he repainted a small area of the back bumper which had paint cracks due to an accident ... so all up 250 bucks LOL :) Admitted his paint work isn't the best, but hey for the money he charged, theres no way he could be beaten ... he also did for a mate a respray just the outer paint, and fixed alot of dents here and there, and also a big dent on the side ... all up 1k i think or there abouts ...
just remember to remind him to not leave the windows down when he works on the car else it'll get dirty lol
https://www.sau.com.au/forums/topic/56196-paintshops/#findComment-1090715
Remember and listen very carefully.
You get what you pay for ESPECIALLY when it comes to paint work. I cannot stress that enough.
If you worship your car and pick every little new chip and stress about it then spend the $$ on a good job.
Ask your self if you really want the paint on the body kit to have more orange peel and look different than the body paint?
Cheap paint work can and will have a slightly different colour (some times a white wash to it), orange peel and visible sanding marks under the paint due to lack of care and time on the prep work.
https://www.sau.com.au/forums/topic/56196-paintshops/#findComment-1095839
    • Connected to plenum towards the rear end. Yes, absolutely required for the ECU. Even Nistune can't save you if you don't have it.
    • Can confirm solenoid makes no difference. I finally removed the solenoid and the wire off my engine loom and there is no issue with boost. Keep in mind, this is the solenoid, and I've got a Nistune. After the boost controller, I ran the car for a day with the solenoid unplugged - no issue. So then I just ripped the whole thing out. Like @GTSBoy mentioned before, the ECU just sends an earth signal for the 2-stage boost. And looking at the wire going into the solenoid, that just had 2 standard wires and did not look important 🤣 As for boost sensor: I saw somewhere that the vacuum line the gauge uses is at the back of the engine on the driver side. I never touched that but assume ECU uses that??? (maybe? Just assuming)
    • I still remember it trying to rip the steering wheel out of my hand when I put it into a 4wd power slide lol
    • Im also amazed how well Attessa holds up to all of the abuse. Especially with the burnouts and crap you guys used to do at Texi!
    • True! I think I'm closer to 06 with the cameras in phones being out there more. And the nearly impossible to use internet web browsers. Or paying for ring tones... Man I hated when we couldn't just compose a ringtone on a Nokia anymore! These days I just hate it if my phone rings, beeps, boops, or vibrates!
