Hey guys just bought my bodykit and wondering if anoyone knows a good place to get it fitted and sprayed? It needs a little bit of prep work.
Need somewhere that does a reasonable job for an good price. I know that you get what you pay for.... but still.... :)
https://www.sau.com.au/forums/topic/56196-paintshops/
yep its procoat ... if you're after something really cheap ... but isn't oo bad ... then he is good ... this is how cheap he is ... mind you i've used him a few times myself and plus i've referred alot of people to him so he gives me mates rates i guess ...
but anyways i cracked my front bumper ... not a small crack ... but a big one ... fixed it .. painted ... paint wasn't too bad either, fitted again, the fitting wasn't too bad, wasnt' that good either, if there was one thing that wasn't good about his work its the fitting, but anyways he repainted a small area of the back bumper which had paint cracks due to an accident ... so all up 250 bucks LOL :) Admitted his paint work isn't the best, but hey for the money he charged, theres no way he could be beaten ... he also did for a mate a respray just the outer paint, and fixed alot of dents here and there, and also a big dent on the side ... all up 1k i think or there abouts ...
just remember to remind him to not leave the windows down when he works on the car else it'll get dirty lol
https://www.sau.com.au/forums/topic/56196-paintshops/#findComment-1090715
Remember and listen very carefully.
You get what you pay for ESPECIALLY when it comes to paint work. I cannot stress that enough.
If you worship your car and pick every little new chip and stress about it then spend the $$ on a good job.
Ask your self if you really want the paint on the body kit to have more orange peel and look different than the body paint?
Cheap paint work can and will have a slightly different colour (some times a white wash to it), orange peel and visible sanding marks under the paint due to lack of care and time on the prep work.
https://www.sau.com.au/forums/topic/56196-paintshops/#findComment-1095839
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
