My GTST has gone to a new home.
jlnewton
 Share
Sold the trusty steed today. Was a great car and after 3 years of trouble free ownership I am a little sad to see it go, I am sure the new owner will have lots of fun in it. It has been sold locally so it may still be spotted from time to time.
:) A minute silence for one of the family has left...........
Cheers guys, was a great car....but it was time to move on. I did let him know all about SAU and the MSC III. He said he may try and come along. And Knore it was less than A, hard to sell GTSTs now, In the 1.5 months I seriously had it up for sale I only had 2 people actually come and look at it, the 2nd bought it. Both said it was one of the cleanest they had seen, so I was lucky I guess.
hey guys.
im the the guy who baught the 33 gtst.
let me asure you that it will stay clean and as stock as i can keep it.
it's my first real skyline. i owned a 31, but needed something nice. and there was jasons car. cheers guys.
its a sweet car. see ya round.
 Share
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
