Sorry, car is a 1988 model, typo
1988 HR31 GTS-X for sale
2 tone gunmetal grey 2 door
RED TOP ECCS RB20DET - not nics
VG30DET TURBO
ABS
R32 five speed (converted from auto)
Has K&N pod filter - bought feb04 - in custom airbox
Car has turbosmart type 3 BOV
3A racing cannon muffler with new piping (june) catback - Car is quite loud
HICAS 4WS.
Car has 280,000km's on it but is in good condition for its age.
Needs a couple of things done - motor is reasonable, clutch doesnt have a lot left in it.
Gearbox is good
turbo uses a bit of oil.
Would be ideal for a silvertop conversion or other RB
Front shocks are shagged and need to be replaced.
Has an RB30 twin core radiator bought new from nissan this year
Diff was rebuilt earlier this year, spent $700
Still has auto diff ratio, so speedo is inaccurate and gearing is tall (quicker off the line)
Interior
Short shifter (very short)
Kenwood CD player
turbo timer (not sure of brand, also shows battery voltage)
Interior is in good cond, drivers seat is a little worn on edge.
Exterior - externally looks good
Has been resprayed sometime in its life, paint is in good condition with only a few blemishes
1988 so has S3 lights and garnish, GTS grill
MFX lip fitted, also have autospoiler ready to fit
Has ADthree kit, aero mudguards and window lips
15 X 7 OS25 Work E-wing emotion rims - deep dish
Good rubber on front, tyres bought new recently
Rears have S/H tyres on them bought to get rego but have good tread
Car has rego till late June 2005 - 6months+ NSW
Car is located in Seaham NSW near Raymond terrace, 30 mins from newcastle
CAR IS NOW SOLD
More pics can be found here
http://photobucket.com/albums/v484/daver31gtsx/GTS-X/
Car was on R31house main page for a couple of months
Dave
https://www.sau.com.au/forums/topic/56198-1998-hr31-gts-x-for-sale-nsw/
  • 3 weeks later...
Hey Dave, Mum and Dad said i could have a loan to buy the car if it is fully mechanically sound eg. safety certificate and road worthy certificate. because i live in qld it has to have nothing wrong with it to re-register it. pm me with a price
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
