I wore my rear passenger side tyre out on my '98 Gts2.5t in 5,000km. The other tyres are all less than half worn. The car has a lock diff, so both rear tyres should wear the same.
The reason for this wear is the car has been set up for drifting. I took it to a wheel alignment place and they reckon that there is a bush inside the rear hub that may have to be replaced. They reckon the car probably has an offset bush in it and it should be returned to std for road use.
Anyone had this experience???? Are they talking sense or crap???? I'd appreciate comments.
PS You can actually see the camber on the wheel with the naked eye.
PPS SK, I need to get this alignment prob fixed, and can't see myself getting to Sydney for a while, so I'm using a local business that reckon they have seen and repaired/modded this problem out. My suspension mods will still go ahead, but I have to be a bit more patient and schedule it and the power fc etc to early next year.
https://www.sau.com.au/forums/topic/56212-camber-on-rear-tyre/
Skylines have adjustable camber on the rear, standard. The range of adjustment is quite small though. Usually not enough to remove enough negative camber after you lower them. So Whiteline have adjustable (eccentric) polyurethane bushes, one set is usually enough, they go on the inner joint of the upper arm. Sometimes you need 2 sets, they go on the outer joint where the upper arm joins the upright.
The rule is to take as much negative out with the standard adjuster and see how much more is needed. If it is more than 1.5 degrees, then you need 2 sets of polyurethane bushes.
Hope that helps.
You'll definitely need some alignment figures to work on. And I wouldnt waste my time with camber offset bushes. Just go the arms for a lil more money and you can install em yourself.
$249 for new ones @
http://www.garage-13.com/suspension.html
$249 for new ones @
The arms have non greasable spherical bushes. On Australian roads with the bumps and dirt, they don't last very long and the knocking will drive you crazy.:(
Since mine just arrived today are there any strategies I for me to employ for getting the most possible wear out of them? Like greasing them up and then putting a huge glob of vasoline over it?
(that's as ingenius as i get with mechanic stuff)
Ask the supplier for a set of seals, some manufacturers have them. The look like litte cups that fit over the spherical bearings and keep the dirt out and the grease in. They obviously have a hole in them for the bolt to go though and you need a pair for each bearing, one each side. They can be plastic or alloy.
The sphericals may have threaded holes in the side for grease nipples, so you can apply grease with a grease gun at pressure from the inside out. This squeezes any dirt to the outside which you can then wipe off. Ask if they have grease nipples as an option.
With both dust covers and internal greasing you might get 10,000k's out of them before the sphericals need replacing. Separately purchased, the sphericals will cost more than the arms, most people just buy new arms when they start knocking. The Japanese manufacturers sometimes use unique sphericals, so you have no choice but to buy complete arms.
Hope that helps:cheers:
OK, how long do the polyurethane bushes last [as opposed to the arms=10,000km with care], and is cost comparible???
A Skyline example, I have a set that has done over 40,000 ks in an R32 GTR. A non Skyline example has done over 100,000 k's on the poly bushes in the front inner uppers of a double wishbone design. It was the old Foulcan tow car we had before the Stagea arrived. The bushes themselves are quite cheap, the labour cost little more. But after you have changed the sphericals several times, I don't think that matters much.:)
Ok here's my results, finally got an alignment.
They recommend a top and bottom bush set for the rear, and just the one set for the front.
They normally deal with Super Pro, but I asked them to get Whiteline [only heard good things about them, haven't heard of Super pro at all{they are probably good to}. They said no problems, Whiteline was OK.
Yeah, best I could do [with the image], had to sharpen it and remove noise as it was.
If you save it, you can zoom in and it's a bit better. The printout is a grey print on white.
The bush kit should do the trick, and according to SK it is the most preferable option. I don't think anybody have aligned the car in a long time.
Gotta agree that bushes are the best option for a road car.
Have to disagree with SK on the spherical bearing deal though. I've got non greasable sphericals on both my castor rods and my rear upper links on an S14. Both have now done over 40,000km with near zero problems. I had to remove the rear arms at one point and apply bearing lock to the spacers either side of the spherical bearing balls to stop the spacers rotating relative to the chassis mounts but otherwise haven't had any trouble with them. The only reason I don't recommend them for mainly street driven cars is the increase in NVH they cause due to the loss of compliance. For hard driven street/track cars they are perfect.
If you were to get adjustable camber arms, do you need to get adjustable toe/traction arms like I was told? My cars an r32 but it would be the same for an r34 wouldn't it?
Very sorry to have hyjacked, but it may be relivant if you do need to change these.
I have no idea what a "traction arm" is, but R32/33/34's all have adjustable toe standard.:)
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
