Also yes Adrian 2rismo it was your example leading the way re the burnout thing I just followed the leader. Now you come to our next track day and follow me?
Check out the SAU add on back.
Guest two.06l
Getting the Groove Rider Fabrications special, including the strut tower tie in support.  Yes still mainly a circuit car and will sacrifice a little weight for better handling for circuit.
Looks like the way we are going, but not until next year as he tells us he is very busy.
Wreckedhead I am pretty confident I will run a 9 in my circuit car before you do and not with current motor, it is for sale as going VQ35 500rwkw and alloy block and 100kg less weight.  I will be waiting for you in the 9 sec club.  Have you even run a 10 and not on Grand Turismo??
thats some funny shit john, do you write your own material. :)
funkymonkey yes it was me, the sun is in your eyes late in the arvo. Then at night the prob I had was that there are no dash lights which we will now correct and often with smoke in the cabin which we need to see where this is coming from and also correct I found it hard to see the tacho. I have a shift light set at 8000rpm and rev cut at 8200rpm.
The smoke may have something to do with the little button labled "smoko" on the centre console... I hear when used in conjunction with the far right pedal this can lead to a lack of vision. Might wanna get that seen to.
Richard
Finally got the tyre pressures right and me sorted on the drag racing thing and late in the night  we cracked the 10's last night at  WSID.  Our second event at drags,  and it was on street tyres.
Exact time was   10.894   1.690 60 foot  and 130.85mph  Ambient temp  22C.
The run after that did a 1.597 60 foot but then missed second gear and then ran out of fuel and night was over anyway.
Off to get a roll cage then will be back next year.
Well done John! Nice short times, too.
In case some are still wondering if I actually did it.
I am not sure even some who know me had to confirm with me thinking I may have made it up. Not exactly sure why this is the case and wondering if I lack credability. I certainly never bull crap so?
Video. http://nismo.com.au/downloads/zed108.wmv
Guest two.06l
gee john those BFs certainly get it out of the hole quick. Well done mate, talk with you on monday.Paul...DIRTgarage.
I saw the 11.5 sec pass and I said " Holie Fark"
I got no doubt Johnny boy !
Well done - don't it feel good to get a quantified baseline performance measurement of your cars potential ?? :)
how can a 10 second pass be indicative of a car's overall performance? I think John's track times already have proven his car's potential... the 10 second pass was just rubbing it in our faces :)
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
    • I'm mark from Idaho.
