hey guys seeing as how there is a much more nicer bling cefiro out there than the rest of us in sydney ..
*cough* james - mys013 = BIATCH (he is one beacuse he has the nicest bling one *cough*
I think we only wiaitng on 2 guys toi get theres this month? or is that after xmas.
hoping to cruise somewhere where there is a blurdy BBQ area...
and yes T_M_B i wont be late. Well not toooooo late.
https://www.sau.com.au/forums/topic/56279-another-nsw-meetup-guys/
Chatswood - woohoo somewhere I actually know that exists in Sydney!!!
Damnit I have to choose if I wanna cruise or go to the suspension place. It's a pity if someone from around the northern beaches/north shore even city wants to go later and cruise down I'll come but I'd like to get a wheel alignment done first....
Hmm decisions decisions!! Drift day on tommorow as well :(
HAHAHAHAHAHAHA you dont all hate me!
Thats so nice of you to send me a present!! I do have a dog and alarms though :)
shutup James we all hate you now.
.... on an un-related matter i wanna send you a present.. what's your address?
....... do you have any dogs ? alarms? anything else that the postman should know about? *shifty*
... what?
O_o
Doesnt look like I will be going anywhere within the next couple of weeks now :)
Spent a few hours buying stock S13 rims to pass a blue slip :bs!: then I had to buy new tyres for these rims which set me back again! didnt make it in time and obviously a few more things happened but I wont go into it, either way I wont have the car till next weekend at the earliest now.
How about... You guys all meet up at byron or something, and all us QLD people (all 2-3 of us) meet you guys there. And you bring us a gift of krispy kream donuts, and we will bring a present of our sunshine!
How does that sound! :)
    • Clutch done also about a year ago got a DCS HD Single Plate. Basically done everything but touch the engine 🤣 But will definitely get a fuel pump and ECU, then start saving 🫡
    • Fuel pump and clutch and ecu that’ll get you to about 230 or so kw, after that the sky’s the limit and the budget blows out faster then you can blink
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
