Hi all
i have got a 95 R33 GTST, with Apexi BOV, 3inch turbo back exhaust, Pod filter with heat shield and running standard boost. i want to know where do i go from here.
do i get a FMIC (Hybrid)
do i get a upgrade computer (Apexi Power FC)
or is there something else that i have over looked that you recommend
Keep in mind i want more power, but am new skylines and do not much about cars, although i'm trying to learn.
and can i get more boost pressure from my car as is with buying a boost controller....if so how?
https://www.sau.com.au/forums/topic/56284-what-should-i-do/
not gonna feel effects of a fmic... unless you get something to tune it like you say a pfc.... but a safc is cheaper and should be fine for your mods so far...thats if you get a fmic...
my suggestion is a ~$60 bleed valve and run 10psi instead of stock then you feel some serious power difference from stock :P
https://www.sau.com.au/forums/topic/56284-what-should-i-do/#findComment-1091535
I see you have done the normal induction and exhaust mods, so adding a FMIC would be a good idea. However as fane said you then have the problem of tuning: S1 R33 GTS-ts are also notorious for having shocking fuel economy if the standard ECU is left in place (ie. no PFC or SAFC) once you do intake + exhaust + FMIC.
Bit of a catch-22. Maybe try the FMIC first, then save for the PFC. Or do it the other way round.. doesn't really matter in the end :P
Lucien.
https://www.sau.com.au/forums/topic/56284-what-should-i-do/#findComment-1091544
Thanks Guys..........this maybe a stupid question but what does SAFC stand for, what are they worth.....
Fane you said to get a bleed valve, are they easy to install yourself? is it simply a plug n play on does it require playing around with to get it work?
https://www.sau.com.au/forums/topic/56284-what-should-i-do/#findComment-1092279
SAFC = Super Air Flow Converter.
Benefit of a catch can is that it 'catches' oil/gas blowby, at least in theory: if is a decent catch can it will have some sort of baffle that will seperate the oil/crud from the air. This stops the oil/crud from recirculating back through your engine.
LW.
https://www.sau.com.au/forums/topic/56284-what-should-i-do/#findComment-1092353
If you want to keep it in one piece, first item should have been the biggest cooler you can afford. Summer is almost here, turbo engines really drop power in the heat and the standard cooler is a joke. It's the best insurance you can buy against pinging or overboost, which is what will happen with bleed valves etc until you can afford a decent aftermarket ecu.
Not much good having a cool sounding BOV with no ring lands left.
There is a well worn path to making power in the R33 in Zoom magazine.
It's pretty spot on as my son's 33 has 170rwkw with cooler, exhaust, blended dump and filter. Now it's run out of fuel so that's fuel pump, regulator, injectors, Apexi pfc and boost control. Then it will be turbo time.
Pretty logical steps.
Stay cool.
https://www.sau.com.au/forums/topic/56284-what-should-i-do/#findComment-1092384
Yep.
Cooler and PFC and bleed valve.
but, opposed to grigor, I would say PFC first. you will get much more bang for your buck, and to deal with the cooler, get your hands on a standard R34 GTT cooler which is good for up to 190 - 200 kW and unless you are on boost all the time, should be fine.
then when you have the money get the big cooler, sell the small one and Bob's your uncle.
Power benifit from FMIC alone, maybe 8-10 rwkW, PFC alone, more like 25rwkW
BASS OUT
https://www.sau.com.au/forums/topic/56284-what-should-i-do/#findComment-1092537
pfc can change ignition and the fuel maps (afrs)
safc can only change the afrs....by tricking the computer with different airflow readings...
www.apexi.com
i would suggest safc over pfc only for price....
bleed valve just snip tube, block stock bleed thingo i think and 2ez your running 10psi with a good fuel map (safc).
so hot weather wont hurt you car at all because of the nice afrs from your safc...
a fmic by itself wont do much, a pfc isnt worth it until you get bigger mods....and if your not planning to do them then i wouldnt bother with pfc and i would just get a safc.
my mods that in my sig is what i called stage 1 in performance....cheap bolts ons and a safc...which i put in myself...then tuned by me and my mechanic with thingo in exhaust to monitor the afrs....my car never knocked.....and i just pulled off my turbo and there is no shaft play.....and i ran 13psi for quite a while....with a fmic ofcourse....always let car warmup before boosting helps look after your turbo and making sure it doesn knock (good fuelmap and safc can monitor)
my suggestion as i said before, is mods below if thats where you are gonna stop....if you are getting a bigger turbo and stuff like that later i would get the pfc to save you the money later on.
EDIT: Mods arnt in sig anymore, so here they are...
note: not including suspension and clutch and crap like that
ebc (short term, bleed valve)
pod
turbo back
safc2
fmic
13psi (10 without fmic)
i think thats it
running 10psi and no fmic or safc i got 13.8 down the 1/4
running 13psi and fmic and safc with about 11.8 afrs (no knocking) i got 13.2 down the 1/4 :)
i would have been happy with that but lost licence and had some spare cash so i got a hi-flow...and need some more tuning so gotta get the pfc :)
if you want anymore info heaps of us have been through that stage and we can help...
https://www.sau.com.au/forums/topic/56284-what-should-i-do/#findComment-1092617
FANE,
Can you help me, i've got two prices for SAFC, once was $170, 5 knob...whatever that means, and the other was $450.
What should i be looking for in a SAFC? brand, specifications.....please keep in mind in know nothing..................
https://www.sau.com.au/forums/topic/56284-what-should-i-do/#findComment-1095086
Forget about the 5 knob thing.
It's very very old.
Best value would be to fork out the moolah for a PowerFC first before anything else.
Then when you do more stuff, you don't need to change your management to cope with it.
https://www.sau.com.au/forums/topic/56284-what-should-i-do/#findComment-1095127
Fane.
I figure that but.
Let's work it out on a bang for buck scale....
PowerFC
Expected result 25rwkW
Cost inc tuning $1500 (group buy and $500 to tune)
= $60 per kilowatt.
SAFC
Expected result 10rwkW
Cost inc tuning $650 ($450 and $200 to tune)
= $65 per kilowatt.
So bang for your buck, and outright increase in grunt. PFC has it.
https://www.sau.com.au/forums/topic/56284-what-should-i-do/#findComment-1095198
Fair enough.
but I had my PowerFC tuned at a local tuner last week for $185.
Is wasn't sure of the prices in Sydney.
Extrapolate and you get $47.50 per kilowatt
Well, as the saying goes.......... Speed costs money. How fast do you want to go?
BASS OUT
https://www.sau.com.au/forums/topic/56284-what-should-i-do/#findComment-1095241
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
