Nismo G-Max Spec III - Triple Plate Clutch
to suit, R33 GTR (pull type), solid center.
has travelled about 15,000klms. clutch isnt slipping, just replaced for a more user friendly item. use as is or rebuild, replacement clutch plates available from nismo or exedy.
looking for $750 ono (worth approx $3500 new)
PM or email for more info.
Just checking would this fit an R32 GTR i would assume
and also whats wrong with it for the price to be so cheap?
Cheers,
Andy
