Friggin' RB20 sounded like a whipper snipper. Get somoe CUBES!!
Don't waste money on Splitfire. Come over and do some maintenance on the current ones.
BTW Ash.....Roy won the burnout, by a MILE.
The Spitfires look like being about $550 delivered, at that price ill just grab them, 5 of the coil packs in my car are 12 year old and done plenty of kms, most of them with the coil pack cover on so have seen plenty of heat in their day.
One fasiled last yaer in which case i just stole an RB25 a SI one off a friend, so rather then fark around ill grab something that should well and truly be up to the job.
  • Replies 45
As you wish. And if they don't fix the miss..........
Couple of tubes of araldite has to be worth a try first. If the miss goes away then splash cash on the splitfires with my humble blessing.
I was thinking some crumpledore coilpacks and high tension leads might be a good try sometime.
:)...i think you bought his last set...only mentioned to him last night that iwant a set and he didnt say he had any:(
Greenline just got back to me. $770...maybe its time to play a bit more with the crud i have at the moment...
What was wrong with your GTR packs, i might grab them and see if i can get a good 6 from the 12...what would you want for them?
    • Is rebuilding it even a thing? Where would the shop find parts for it? I looked at some off these local online stores for my r34 and suprisingly they had brand new aftetmarket ones for $600-800 I think. I guess r32 might be a bit tougher.
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to move wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
