Originally posted by adam 32
lowest structural part has to be 100mm off the ground (this is normally the chasis rails) remember the exhaust is NOT structural and therefore doesnt count...
see your pm for full detials
Are spoilers classed as structural? and what about clearance from the top of the tyre to the body? If any one can clarify this it would be much appreciated as there is a LOT of uncertainty with measurements and clearance heights!
https://www.sau.com.au/forums/topic/5636-got-my-car-today/#findComment-85357
Originally posted by GR33DyMANGO
all i can say is totally radtech! heeehe
Radtech??:confused: ahh maybe im just gettin old
BTW: whats a good paint job like that worth? i could 'prolly' (i use the word tenatively) do it myself but i prolly couldnt be assed:drooling:
https://www.sau.com.au/forums/topic/5636-got-my-car-today/#findComment-85475
daniel
there are 2 measurements that are commonly used, ground clearance and centre of axel to wheel arch.
1) the car must be 100mm off the ground from any structural point, bodykits are not structural. normally the lowest point is the chassis rail.
2) there is a certain distance that needs to be met on every car from the centre of the axel to the wheel arch. on R32's (when i had to go thru compliancing) it is 350mm. this varies from car to car and is about 10-20mm lower than the std height.
when going over the pits it depends alot on the overall presentation of the car, if it is a fairly tidy looking and 'tastefully' modified car then you can normally slide through. They tend to pick on riced up cars which are rediculously low or loud...
https://www.sau.com.au/forums/topic/5636-got-my-car-today/#findComment-85497
Guest GR33DyMANGO
Radtech?? ahh maybe im just gettin old
haha.. my friends made it up when were skating at the leederville skatepark about 8 months ago. my mate skated around it a motorbike jacket and helmet looking totally homo.. we all laughed and someone called him radtech. if u r REALLY radtech.. then you;re radtech invincible.. haha.. sounds pretty silly.. but it has too many memories.
then last week.. my little brothers friends have this tv show on channel 31, mondays at 7.30pm called EXTREME WA... and they said radtech about 8 times.. we;re all trying to make radtech a new 'cool' word.. haha.. we do some pretty crazy things.. hehe..
https://www.sau.com.au/forums/topic/5636-got-my-car-today/#findComment-85529
Well hopefully they look upon my car favourably :P
I really can't be bothered with those sorta hassles.
It's only really got an exhaust and it's not loud at all so I should be ok. Doesn't even have a pod filter :D
Tomorrow morning will tell hehe :P
Cheers for the kind words Justino :D
https://www.sau.com.au/forums/topic/5636-got-my-car-today/#findComment-85589
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
