Originally posted by adam 32
lowest structural part has to be 100mm off the ground (this is normally the chasis rails) remember the exhaust is NOT structural and therefore doesnt count...
see your pm for full detials
Are spoilers classed as structural? and what about clearance from the top of the tyre to the body? If any one can clarify this it would be much appreciated as there is a LOT of uncertainty with measurements and clearance heights!
https://www.sau.com.au/forums/topic/5636-got-my-car-today/#findComment-85357
Originally posted by GR33DyMANGO
all i can say is totally radtech! heeehe
Radtech??:confused: ahh maybe im just gettin old
BTW: whats a good paint job like that worth? i could 'prolly' (i use the word tenatively) do it myself but i prolly couldnt be assed:drooling:
https://www.sau.com.au/forums/topic/5636-got-my-car-today/#findComment-85475
daniel
there are 2 measurements that are commonly used, ground clearance and centre of axel to wheel arch.
1) the car must be 100mm off the ground from any structural point, bodykits are not structural. normally the lowest point is the chassis rail.
2) there is a certain distance that needs to be met on every car from the centre of the axel to the wheel arch. on R32's (when i had to go thru compliancing) it is 350mm. this varies from car to car and is about 10-20mm lower than the std height.
when going over the pits it depends alot on the overall presentation of the car, if it is a fairly tidy looking and 'tastefully' modified car then you can normally slide through. They tend to pick on riced up cars which are rediculously low or loud...
https://www.sau.com.au/forums/topic/5636-got-my-car-today/#findComment-85497
Guest GR33DyMANGO
Radtech?? ahh maybe im just gettin old
haha.. my friends made it up when were skating at the leederville skatepark about 8 months ago. my mate skated around it a motorbike jacket and helmet looking totally homo.. we all laughed and someone called him radtech. if u r REALLY radtech.. then you;re radtech invincible.. haha.. sounds pretty silly.. but it has too many memories.
then last week.. my little brothers friends have this tv show on channel 31, mondays at 7.30pm called EXTREME WA... and they said radtech about 8 times.. we;re all trying to make radtech a new 'cool' word.. haha.. we do some pretty crazy things.. hehe..
https://www.sau.com.au/forums/topic/5636-got-my-car-today/#findComment-85529
Well hopefully they look upon my car favourably :P
I really can't be bothered with those sorta hassles.
It's only really got an exhaust and it's not loud at all so I should be ok. Doesn't even have a pod filter :D
Tomorrow morning will tell hehe :P
Cheers for the kind words Justino :D
https://www.sau.com.au/forums/topic/5636-got-my-car-today/#findComment-85589
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
    • Uniclutch install vid, RB Track edition.   Highlight reel is very drive able, not noisy but still heavy with the clutch master he has.
