which clutch?
hmmm that's not ideal. This is a pretty new engine right, will be interesting if your engine guy has any theories about causes
By TurboTapin · Posted
A universal ball joint removal c press kit is better money spent and will work for the Hicas ball joints. Here's a 45$ CAD Example. ATPEAM Heavy Duty Ball Joint Press Kit with 4WD Adapters | Professional 4 in 1 Ball Joint Press Removal and Installation Tool for Cars and Trucks | Universal Ball Joint Tool with Storage Case, Ball Joint & Tie Rod Tools - Amazon Canada -
By The Skyline Guy r34 · Posted
So there is no other way to remove and install the ball joints then to buy the Frenchys kit? -
Just to close off this post with the cause of my oil consumption issues. Vertical scoring and glazing at the bottom of cylinder 6. I'm not happy, but at least I finally found something. I'll pull it and get it apart asap. Hopefully I don't need to go one size up in piston.
