hey All,
Who can tell me if R32 front struts will fit in a series 1 bluebird TRX, I know that S13 struts are too fat to fit. And also will the front hubs bolt on so it can have r32 rotors and four piston calipers? Oh also I have some NSW numberplates I want to get rid of. I've had them for the last two years: R33GTR so if any one is interested or knows anyone let'em know. 0421 67 0022 Cheers
https://www.sau.com.au/forums/topic/56418-trx-r32-struts/
hey All,
R32's do not have struts as such, but have multi-link suspension. Your bluebird has macpherson struts as do S13's. The 2 types are totally different designs with no interchangeable suspension parts. Your best bet would be to try to get hold of some import HR31 turbo struts which might do the job, but I suspect they are v similar to the S13 type.
https://www.sau.com.au/forums/topic/56418-trx-r32-struts/#findComment-1093667
So you're saying that R32's have upper and lower control arms at the front, what sort of spring/shock set-up? they more like coilovers? do you know what sort of suspension cefiro's have?
Yes, upper and lower control arms, with separate shock absorbers and springs (coilovers, if you like - personally I would argue that macpherson struts are 'coil over', but anyway......)
I don't know much about cef's, but I'd guess they have similar suspension to HR31 Skylines - meggala would be the best to ask.
https://www.sau.com.au/forums/topic/56418-trx-r32-struts/#findComment-1093788
hey All,
Have you tried using S13 coil overs?? Im pretty sure you'll find that they'll fit....
https://www.sau.com.au/forums/topic/56418-trx-r32-struts/#findComment-1095036
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
