  • Replies 70
Going by some quick research, so long as you have quad pintle injectors like HKS/Nismo/Apexi then you should have zero problems with idle and fuel economy. It seems the RX7 and SARD injectors are the non-DOHC friendly types and thus you get what you pay for. It seems people with SR20s have had no problems with 740cc quad pintles!
joel mate rx7 ones are fine the spray is pretty much a stream as you say but this is due to the pinttle cap hole being to narrow you need to use toyota ones and drill them out slightly but the patter is quite narrow as opposed to your nismo quad pinttle varieties, but 550cc is small so the differences will be quite small....Also some of the earlier rx7 injectors will actually require you to bore the hole in your head slightly larger so be carefull what you buy if you go down that route. Personally i could never pay the ridiculous prices asked for by the jap brand injectors its bloody daylight robbery.. i use holley injectors in my car (110lbs= 1180cc Units), cause they are cheap, never fail, and alot of the product range is designed for methonol so the seals are alot higher grade but you will not get you your misty spray with these they are pretty savage but very effective!!!!
the rochesters are the same as the holly design they have holes that seperate the spray to give a finer spray pattern but are still single needle or pintle design i will post a pic of the design!!!
Hi Joel, I have a set of 555cc nismo injectors in my RB20. I actually had them checked for flow before i installed them and the results showed that they all flowed Exactly the same amount - 600cc. So yeah, im happy with them but i can't comment on fuel economy as i had a bigger turbo and stuff put on at the same time :D
Generally bigger turbo's under normal driving conditions result in better fuel economy as you tend to be on boost less.
Note the normal driving conditions. :D
Has the fuel consumption changed dramatically even with the mods or?!?
Note the normal driving conditions. :)
Fuel consumption has got a lot better now that i'm running the stock ecu chipped, especially for highway cruising compared with the microtech that i previously had.
I am lucky to get 300km/h to a tank now with 550cc injectors and GT30 turbo, and thats driving to work and back everyday when my car rarely sees over 80km/h or 4000rpm
One shot at "300km/h" per tank... nice effort mate :P
LOL above
Hey I have YELLOW 555s
Can the colour give an indication on what injectors i may have cause i have no idea
Cheers :D
Well they won't be nismo ones because they are pink, so i dunno....
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
