G'day guys,
i've got a HR31 GTS-x with a sunroof.. i can't fit in it with a helmet on due to the sunroof lowering the interior roof height
my question is: Have any of your run into this problem? And how have you over come it, in the way of aftermarket seats?
As everyone make and model of car is different to whether it will raise your in the car or lower it, i was just wondering if any of your guys have found a seat that actually lowers your in the car.. i need about.. i need to be lowered between 1 - 2 inches to comfortably fit my head in with a helmet.
Any information you could pass onto me would be fantastic
Thanks in advance
Cheers
Ben
https://www.sau.com.au/forums/topic/56456-questions-about-seats/
G'day guys,
Thanks in advance
Cheers
Ben
Following from adam's comments yes my head hits my roof in my car as well and im only 5'10...About the only way to deal with it is to make custom rails up and lower ur seating position
Yeah, the roofs are too bloody low in the DR30's at least, I have to tilt the seat back a bit to fit and I still touch, but i refuse to adopt the dickhead seat position, I've got a feeling half the reason i don't seem to attract police attention is that my seat is quite upright
I have a Recaro in my R32 - I've had it for many years. It allows me to sit a bit lower in the car so that when I wear my helmet, I don't need to slide forward and down.
The degree of lowering depends on how well the seat is adapted to fit in the car.
Go and talk to Tony at IdealSeat in Moorabbin.
interesting.. looking pretty doubtful atm :)
boof; you mention custom rails.. where would i go to inquire about getting them made up? and what would a reasonable price i should expect to pay?
thanks for the input guys :)
Cheers
Ben
As i don't live in melbourne i have NFI where u would go, but any workshop should be able to perform the work, might even try using a aftermarket bucket (sparco) or similar and see what the go is then
It's all in the seat and seat rail.
Get one that is lower than standard - much lower.
It will lower your centre of gravity (slightly) and lower your overall sitting position without having to move your seat (since you're basically going directly down).
Disadvantage maybe a little impractical for the street as your field of vision is also lowered.
Personally I like my lowered seat. I have room in my car for a helmet and I have a sunroof. (Although admittedly it's not a DR).
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
    • @Dose Pipe Sutututu I read your replies RE: R35 GTR MAFs, any ideal spots to put on? Obviously will need the adapter plate. Will be having a cross over intercooler fitted shortly, would putting it a bit before the TB be okay?
