I know that many people have been waiting for the manuals and most of us probably have them.
I have created a little menu system whereby you can select between the two manuals.
It is autorun when you insert the CD with nice little icons and stuff. I have also included acrobat reader 5.1 so you can read them if you don't already have it installed.
Anyway....I have cable so download the complete ISO image or I have compressed it into tiny bits for all you dial-up people.
Let me know what you all think.
I'm gonna try to do the same but include the 33 manual when I find it.
Cheers.
ftp://[email protected]:77
https://www.sau.com.au/forums/topic/56457-r32-gtr-and-gtst-manuals/
if you are using an ftp client then the user name is Skyline and the port is 77
Ip is 203.45.164.45 and there is no password
I can see the connections on my server but the downloads aren't happening so I'm not sure what the prob is. My firewall can't be it coz it won't let you in otherwise and it accepts all connections on 77. So i've turned it off anyway. And I put maximum users to infinite instead of 3, lol my bad.
Try again and see what happens.
yup. I have the R32 GTR manual, and the R32 engine manuals, but have never seen the R32 GTSt manual, if it exists it would be awesome. Just wanted to find out the contents of the ISO before I downloaded it.
yep, it's definately the GTST manual and the GTR manual
will do CA18, RB20E/DE/DET, RB25DET, RB26DETT - GTST
and the GTR manual is the RB26DETT plus all the 4WD systems
But I have made a menu system so you can select between the two.
it autoruns when you put the cd in.
oh.... lol then I already have them...
GTSt's never came with the RB26DETT. I'd say that that's just the engine manual for the R32. Does it cover anything other than the engine and ECU, like interior trim and chassis?
Its still worth the download though. Might just wanna rename it to R32 Engine Manual so you don't get anyone's hopes up.
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
