Any differences from factory in the Rb26dett pistons/ rods/ crank or block?? Or have they been the same since the r32??
Can you use pistons and rods from a r34gtr engine in a r32gtr engine??
Is 350rwkw achievable on a stock rb26dett bottom end with good compression and no fatal signs of blowing up soon??
If im correct this set up should do a mid to low 11 at the high 120mph mark.
https://www.sau.com.au/forums/topic/56488-gtr-bottom-end-any-diff-between-3234/
Harun, 350kw shouldnt be a problem so long as the engine is in good condition with good tuning and plentiful fuel supply.
As for the bottom end differences, im not 100% so I will leave that for someone else to answer :P
The crank collar on the R32s is the only difference I know. If you keep the revs to within factory limits you shouldn't have an issue with that.
Pistons and rods are interchangable if not identical. They may have changed the quality of the metals in the hardware over the period of 10 years but I'm not sure. The top end is slightly different, but that wasn't your question.
350rwkw is quite achievable, the question is, what do you intend to do with that 350rwkw. It should be OK on the drag strip but may be stressed on the circuit.
No problems with the low 11s and mid to high 120mph either.
Thanks for the reply guys.
The car would be set up for more circuit racing. How ever it will see the occasional Drag/ drift day.
Im not too wise on GTR engines and not sure of how much power they can take before you need to upgrade the internals.
Emre: That is what i heard. Same size/ type/ style piston and rods though different materials. Also i believe r34 has larger valves and different cam to the r32/3 engine.
i got an r33 gtr crank in my rb25 which has the larger oil pump drive to suit the n1 oil pump we put on also. If u get the earlier crank with the smaller drive it cost roughly 500 to machine to suit. If ur swapping whole engine for rb26 then i dont think u will have a drama
    • I recently got their dbw 74mm throttle body and pedal kit. It is sensational quality especially the wiring harnesses. Unfortunately I can’t answer u about the fitment to stock inlet manifold as I’m going Rahjab Racing forward plenum. Only one thing to be careful of is understand u have to pay gst and import fees if your purchase is over $1,000 in one shipment.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
