Motec is fine if you dont want to run over 10,000 RPM (Which is the majority of us)
Dave has had great success with autronic.
Power FC is fine if you like AFM's. (although there is a version that allows you to remove them, i think its the D-Jetro version?).
Personally I would never run a piggy back or SAFC. Not that their bad, they serve their purpose, I would just rather spend my money only once on management.
These are ther only options I personally would opt for. Of course it also depends on your mods/power level.
https://www.sau.com.au/forums/topic/56489-peoples-thoughts/#findComment-1094531
i prefer an AFM over a map sensor for accuracy and scalabilty without having to retune. Therefore motec is out.
However if you are running HUGE amounts of boost (15PSI plus) then the AFM tends to give incorrect readings or is not that effective, in which case you'll need a map sensor.
https://www.sau.com.au/forums/topic/56489-peoples-thoughts/#findComment-1094551
Dude its not as if a Motec 'falls out of tune', so i dont know why a motec would be out, apart from the cost.
ever seen an AFM fail and lean out an engine? not nice. Bang for your buck would without question be the Power FC.
https://www.sau.com.au/forums/topic/56489-peoples-thoughts/#findComment-1094574
I assumed since the motec used a map sensor (which dosen't measure airflow directly and uses on the fly calculations), it'd have to be re-calibrated even if you made a small change like an intake mod.
https://www.sau.com.au/forums/topic/56489-peoples-thoughts/#findComment-1094827
Shan 15psi of boost is not really HUGE anounts of boost for a afm.
There are cars running 2 bar boost with afm's without problems.
AFM is also good for closed loop and better fuel economy on a daily driven car
https://www.sau.com.au/forums/topic/56489-peoples-thoughts/#findComment-1095078
yeah true 15psi isnt huge for some cars (bad placement on my part). But on my old 180sx whenever we upped the boost over 15 PSI I always got some errors in the AFM. At about 14PSI it seemed to be OK. Then again I was using the stock standard CA18DET AFM, and not a Z32 one or even a skyline one.
https://www.sau.com.au/forums/topic/56489-peoples-thoughts/#findComment-1095099
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
    • Wives never seem to find things funny. Especially when they're trying to sleep, and you've found the new funniest thing ever. I've never seen someone be able to get try and be cranky with me, while they're holding back fits of laughter... 😛   Also, I tell mine it's payback anyway. She has BiPolar. So the household can get quite emotionally wild at times 😛
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
