The best rims ever seen!!
  Quote
Originally posted by kimron
yo INASNT those are cool what the hell are them?:eek:
photoshopped rims! :D
I got 17inch OZ racing rims!
rs73
according to the thread dr drift made about all the fibreglass parts there should be a guy using his car to make the template for the series 2 lids!
G'day Kabab,
I reckon the TE37 wheels look awesome.I have always wanted a set but they are so expensive new.I just found out about a 2nd hand set of 17x9s that JMS had, so I grabbed 'em & they are getting painted gold at the moment.(Going on the R33 with Nittos)
The R34 GTR wheels do look good, but I wanted something different on my one, so I sold them(I know - silly.Should of kept em) I already had the 18x10 works wheels from the R33 & I think they suit the blue R34 really well.Most people seem to prefer the std wheels on it , but just about every magazine has a couple of ads with pictures of std R34 GTRs & I wanted something unique.
Will be interesting to see what the R34 looks like with Gold TE37s
on it.
Zenetti Tek 19" on an R33 25t. I swear to god- as soon as my other car sells, I'm there!
Sure they're showy, but I reckon they're classy.
And as the competition between all these wheel & tyre outlets heats up further, tyre prices will (hopefully) come down further.
Not that I go through that many of them :)
    • Might piggy back off this thread since there's been a good discussion about PWM.   I purchased a Walbro 460 F90000267 and have been looking into PWM to understand it. It was purchased more of a future proof as my original OEM fuel pump died (r33 below 200kw) and figured I'd just upgrade it to this. That's when it hit me that a pump this big can cause more dramas with such high amperage draw and heating of the fuel pump being on 100% all the time in such a mild setup.   I have a Nexus R3 and slowly collecting power mods but I was looking into the PWM feature on the NSP software:   Then looking at the graph from the fuel pump:     Am I safe to assume reducing duty cycle to 50% for example would make the pump run like a 230/lph ? Where does the PWM come in all of this ?   I've gone down the rabbit hole of PWM fuel pumps and it seems there are many differing opinions on how to go about it 馃槄
    • Thank you, this will keep me busy for a bit.  I will update progression.
    • That specific one would be an exchange part, meaning I'd have to send mine to them. Plus it looks like a non AWD sump, which won't work for me. There is one or two shops in my country that I can ask to do a sump extension job and it'd most likely end up being cheaper than sending mine to AUS or NZ and getting one back, and quicker too.
    • Rear turbo is leaky, most likely at the oil drain. From what I could see with my boroscope it seemed to have seeped out at the very top of that return hose. Is it possible that the oil climbs up that hose to then leak out? Yup, coolant leak on the hot side of the engine, only noticed after seeing clear rusty residue in the block right from the turbo oil feed downwards to the pan, and red droplets hanging from the pan. No clear sign yet from where it comes, and most of the lines there are hardlines right? Last year, seeing those red drops, I thought it was power steering, will be glad if that is not leaky at least. Another leaking hose I found by chance is the lower of the two heater core hoses coming from the firewall to the back of the head. That one is not too bad to get to if I have to replace.
    • I think for response I'm already kind of out there no? he -5s are not the best pick for that as the Internet tells me. Maybe I should switch to -7s while I still can? Though that almost definitely warrants an engine pull along with the other issues I have.
