Hi ppls,
After the recent engine build up I've got some parts left over that will hopefully get me closer to that PowerFC. ;)
RB20DET Engine - Will seperate head, rods, pistons, oil pump - everything.
The motor runs 100% perfect with 140-145psi in all cylinders.
- Make an offer on Parts, all offers are considered.
RB20DET Chrome-Molly Lightened Flywheel & Extreem 30% HD Organic Full Face Clutch.
Ring Gear Included
No thrust bearing
Worn but not slipping clutch plate.
No lips or signs of wear on the flywheel & pressure plate apart from the discolouration due to a little bit of oil that got in there from a seeping input shaft seal.
~6kg's which is 4kg's lighter than the factory item.
- $200 - SOLD!
Z32 AFM Plug & Wires + Wiring Diagram
- $25
http://www.nismo.com.au/pricelists/priceli...ylineclutch.htm
Scroll down around half way down to UAS SUPER LIGHT BILLET FLYWHEEL.
They claim it weighs 6.5kg's.
BUT the one they now sell has a few holes drilled in to it.
My scales tell me the flywheel weighs 6kg's.
If you compare the back of my flywheel to the UAS one mine has a little less material (hence the 2 steps)
is it the stock flywheel that has been lightened? or a fully aftermarket peice? well balanced?
PM me with what you would take inc shipping without the clutch.
i will buy it ;)
Its obviously not the stock flywheel lightened as the stock flywheel isn't molly. :P
Price is the same for the flywheel inc or not inc the clutch.
I have now 2 people interested and am getting a shipping price today.
75 Degree Sidewayz
Make an offer on the Head.
The head comes with:
  • Rocker Covers
  • Cam Gears
  • No Coils
  • No Center Coil cover
  • No Cam belt cover
Busy2k, I will have a spare rb20 afm once the PowerFC is here. :(
75 Degree Sidewayz
  • Rocker Covers
  • Cam Gears
  • No Coils
  • No Cam belt cover
Busy2k, I will have a spare rb20 afm once the PowerFC is here. ;)
No thats on the RB30DET with the stock turbo at the moment.
When the turbo is sold at a later date it will be sold with the turbo.
Postage for the Flywheel & Clutch is ~$15.90 to Melb/Vic/WA.
Postage should be no more than $20.
I already said I'd buy it if the other guys aren't going to put their money where their mouth is.. send me your account details and I'll transfer in straight away :D
Joel, do you have exhaust cam and CAS? Shaun is after these for a customer, I was going to pull them off my spare motor, but I would rather keep it whole
    • Surely the merged entity will be called "Honda" given the relative company values. I've got to be honest, I don't understand how merging 2 companies that missed EVs (despite Nissan making the first mass produced one) will solve their problems
    • If you haven't bought the ECU yet, I would strongly consider buying a modern ECU. Yes it is very easy to setup and tune, however it is lacking many of the features of a modern ECU. The pro plug in is something like 10 or 12 years old now? Can't remember exactly but it is very dated now. In that time the Elite was released and now we have the Nexus platform.  I would strongly consider not buying the ECU that is 3 generations old now (especially as it isn't a cheap ECU!).
    • Im happy for it as long as it means reanult gets the boot
    • Sorry I should have been more clear with the previous post.  The block is a sanding block - picture something like this https://motorguard.com/product/motor-guard-bgr161-bgr16-1-rigid-psa-sanding-block-2-5-8-x-16/ The guide coat is the paint It's two separate things I was talking about, there is no "block guide coat".
    • Maybe more accurately, you aren't just dulling the existing paint, you are giving the new paint something to 'grab on to'. By sanding the existing paint, you're creating a bunch of pores for the new paint to hook on to.  You can lay new paint over existing paint without sanding it, might last a year or two then sad times. The paint will peal/flake off in huge chunks. By sanding it, the new paint is able to hang onto it and won't flake off.  Depends on the primer you are using. When you buy your paint, as the paint supplier what grit of sand paper to use before you lay down the primer.  Use whatever you like as a guide coat. Pick a colour that really stands out in contrast to the paint. So say your sanding/painting a currently white car, using a black guide coat would work well. You very lightly lay the black guide coat down, then as you sand the car with the large block, all the high spots and low spots will stand out as the black paint is sanded off (or isn't sanded off).  When you buy your paint, hit up your supplier for recommendations for what paint to use for a guide coat if you're unsure what would work well with your setup.
