AuotTrend.TV (Japan) mini-article on HSV Maloo
Far be it from me to report anything about Holden, I guess it's more to do with how little press the HSV Maloo is getting in Japan. Holden lovers, you probably couldn't care less what the Japanese think... well, back at ya, I assure you they aren't spending too much time thinking about Holden anyway!
The article:
ホールデン HSV MALOO
豪州からやってきたトラックの形をしたスーパーカー
photo_4-s.jpgホールデンは豪州のGM系メーカー。GM傘下のOEM車の他、オリジナル車も販売する。中でも個性的なのがUTE(ユート)。主力セダンのコモドアがベースのピックアップで、全長は5メートル超とオージーサイズ。「HSV MALOO(マルー)」は、そのUTEをホールデンの高性能車両開発部門「HSV」がチューンしたもの。コルベットと同じ5.7リッターV8エンジンは387馬力を誇り、0-400mは13.5秒を達成。まさにコルベットのピックアップ版。
And translated:
Holden HSV Maloo
From Australia, a super-car in the form of a Truck. (thats what it says! ;))
Holden is a manufacturer which is part of GM. Holden sell original vehicles along side OEM vehicles from GM One vehicle in particular is the "Ute". Based on the brand leading Commodore sedan, the Ute is "Aussie sized" and measures 5m in length. The HSV Maloo Ute is tuned by their vehicle development section HSV. The 5.7L engine from the Corvette is used producing 387hp, with a 0 - 400m time of 13.5 seconds. It's just like a pickup version of a Corvette.
At over 6,000,000 yen, I don't think they'll sell at all.
The shop or office in Japan selling it is in Aichi or Nagoya IIRC.
They will sell as many as Corvette has sold...and how many Corvettes do you see here 2-3 in the 5 years I have been here.
But certainly good on Holden for making an Aussie presence.
http://www.holden.co.jp/
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
    • For anyone that comes here looking for answers on what can go wrong with gts-4 to rb25detneo swap. The Gloria's awd sump is different and does not fit. The rb25neo from stagea are exactly the same sump bolt pattern and axel alignment. Castings numbers are different on Gloria's blocks and oilpans if they need to be identified.
    • I have information on this for anyone that comes looking again. https://www.facebook.com/share/p/18gsbFaYTU/ The rb25det neo from the stagea has the same sumo as rb26 and r32 gts4 (and other awd models). The sump that has caused so many problems during swaps are from the awd neo Gloria's. The casting numbers on the block and oil pans are different so this may help identify if you can't confirm where the motor came from
    • Not feasible to fix the boot lid you had? Damage looked minor/hard to even see :p Source: Drove into something recently and you should be happy you didn't!
    • Another new used boot arrived at the painters, it was sent back as there was nearly as much damage as the original one I want to replace  Finding a clean used boot lid is proving problematic, and I'm not keen on dropping $1500 on a new one from Mazda Sigh....
