how can i tune up SAFC 2 for my car r33 gtst??
how come my knocking and correction is stay in 0...doesnt work at all!!!
and how can i increse power with that?? i got it on my car now...
b4 i got it ppl saying it could increse abit of power but dont think so...
damn it i should just get RSM then ....
so can any1 answer me and teach me how to set up in order to increase a little of power... plz thx
https://www.sau.com.au/forums/topic/56524-safc-2-for-r33-gtst-help/
ok, i will try and help
the SAFC 2, is uses to tune ur AFR so yes it can make you car faster and run better if tune right.
now the best way to tune a safc is on a dyno, so basicly go down to ur local tuning workshop and get them to tune it up for u, im almost 100%sure there tune will be 10times better than u tring to do it
so the best way to get the best performance is to get dyno tune up right??
i c thx mate haha...around $200?? any1 knows good shop for tune up in brisbane???
you have to tune your knock sensor and the correction is for the afrs....just to clarify...
and safc put on your engine wont do anything.....without changing it...
but dont screw with the correction unless you get it on a dyno or something to monitor your afrs....
knock sensor can be tuned tho....shows you how to do ti in your manual...also found here www.apexi.com in documentation
knock sensor should read 0 all the time thats good if it does....only start to get worried if it goes past 60 odd
Yep after you've 'trained' the SAFC II for knock sensing, >60 is very slight knocking, 100ish is level that you should do something about, and getting towards 200 is gettin more serious (should be audiable by then).
Make sure you 'train' the SAFC when the engine is fully warmed up. Btw, the knocking levels between the PowerFC and SAFC are different (dont ask me why). 60 on the Power FC would be doom for your engine...
the safc2 is a great device and is totally different from the rsm... i got some good power gains from mine and it is good if you don't wanna do too much to your car...
thx ur guys... is it right? if my knocking is always starts with 0...then it becomes larger like 8 or 9
    • But we haven't even gotten to the point of talking about stateless controllers or any of the good stuff yet!
    • You guys need to take this discussion to another thread if you want to continue it, most of the last 2 pages has nothing to do with OP's questions and situation
    • And this, is just ONE major issue for closed loop control, particularly using PID. One such issue that is created right here, is integrator wind up. But you know GTSBoy, "it's just a simple PID controller"...
    • Nah. For something like boost control I wouldn't start my design with PID. I'd go with something that originates in the fuzzy logic world and use an emergency function or similar concept. PID can and does work, but at its fundamental level it is not suited to quick action. I'd be reasonably sure that the Profecs et al all transitioned to a fuzzy algorithm back in the 90s. Keep in mind also that where and when I have previously talked about using a Profec, I'm usually talking about only doing an open loop system anyway. All this talk of PID and other algorithms only comes into play when you're talking closed loop boost control, and in the context of what the OP needs and wants, we're probably actually in the realm of open loop anyway. Closed loop boost control has always bothered me, because if you sense the process value (ie the boost measurement that you want to control) in the plenum (after the throttle), then boost control to achieve a target is only desirable at WOT. When you are not WOT, you do not want the the boost to be as high as it can be (ie 100% of target). That's why you do not have the throttle at WO. You're attempting to not go as fast as you can. If the process variable is measured upstream of the throttle (ie in an RB26 plenum, or the cold side pipework in others) then yeah, sure, run the boost controller closed loop to hit a target boost there, and then the throttle does what it is supposed to do. Just for utter clarity.... an old Profec B Spec II (or whatever it is called, and I've got one, and I never look at it, so I can't remember!) and similar might have a MAP sensor, and it might show you the actual boost in the plenum (when the MAP sensor is connected to the plenum) but it does not use that value to decide what it is doing to control the boost, except to control the gating effect (where it stops holding the gate closed on the boost ramp). It's not closed loop at all. Once the gate is released, it's just the solenoid flailing away at whatever duty cycle was configured when it was set up. I'm sure that there are many people who do not understand the above points and wonder wtf is going on.
    • This has clearly gone off on quite a tangent but the suggestion was "go standalone because you probably aren't going to stop at just exhaust + a mild tune and manual boost controller", not "buy a standalone purely for a boost controller". If the scope does in fact stop creeping at an EBC then sure, buy an EVC7 or Profec or whatever else people like to run and stop there. And I have yet to see any kind of aftermarket boost control that is more complicated than a PID controller with some accounting for edge cases. Control system theory is an incredibly vast field yet somehow we always end up back at some variant of a PID controller, maybe with some work done to linearize things. I have done quite a lot, but I don't care to indulge in those pissing matches, hence posting primary sources. I deal with people quite frequently that scream and shout about how their opinion matters more because they've shipped more x or y, it doesn't change the reality of the data they're trying to disagree with. Arguing that the source material is wrong is an entirely separate point and while my experience obviously doesn't matter here I've rarely seen factory service manuals be incorrect about something. It's not some random poorly documented internal software tool that is constantly being patched to barely work. It's also not that hard to just read the Japanese and double check translations either. Especially in automotive parts most of it is loanwords anyways.
