Hey all,
Took my line out for a drive over the weekend and it looks like I've finally broken my tacho (stock) after all those trips to the redline :P On start up the tacho works fine and shows idle around the 1k mark (normal). When driving the tacho reads fine between 0-2500rpm but once the revs go past that mark it either drops to 0 or jumps all over the place. Funny thing is that when changing gears etc and the revs drop down past the 2500 mark the tacho starts reading fine again???
Now when something mech goes wrong in my car, I'm pretty good at diagnosing the prob but with gauges and other elec items I'm pretty clueless. Are the stock tacho sensors off the gearbox or do they read off a pulse from the coil packs? Also are there simple things I can check to make sure a connection hasn't come loose or something? Finally has this happened to anyone in vic and can you recommend a fix or a good auto elec?
Any info or help would be much appreciated.....
https://www.sau.com.au/forums/topic/56544-finally-broke-my-tacho/
As I understand it, the ECU works out RPM based on the crank angle sensor, ie it calculates the CAS's speed. Then the ECU send signals to the tacho and the tacho just shows what's happening.
I'm no electronics genius so I have NFI what's actually wrong here, but losing the tacho feed is not uncommon on R33s. I lost mine, but it stayed on zero, it didn't move no matter what. I just changed the ECU and off it went again. Maybe scab someone else's ECU for a test?
Revhead.....thanks for the info......hmmm interesting considering I have a wolf 3d replacement comp!!! I have my stock ecu so I might spend some time swapping them over to see if it is the comp...thanks I'll look into that (at least I'll be able to determine if it is the ecu or something else)
Benjiman74......very interested in the nismo item if it does end up being the tacho, if you could hold onto it for a couple of days till I check ecus etc that would be great otherwise if you get an offer you are happy with before that, so be it.
Ant mine does the same, even after I changed to PFC.
Apparently the tacho can be pulled out easily and the tracks cleaned as they get a bit corroded or something. Hearsay only but worth a look. Unfortunately I'm snowed for time to check but will do so after I get back from OS on 5th Dec
hey ant i had this exact same problem. past around 2500rpm it would go nuts. i found it was when i got my apexi rsm installed, the stock rev output signal is set to about 3000 rpm so when it triggers that it somehow made the tacho go nuts, no idea why. you can use the rev output relay on the rsm to control things like shifts lights etc but mine wasnt hooked up to anything but the setting was still there, go over 3000rpm bang tachno goes psycho as no idea why. fix was to set the rev output value to 8500rpm as i can never reach that
not sure what it could be in your case but i have seen what you are talking aobut
also when it would happen the hicas light would flash for some random reason too
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
    • I did say no low balling (Insert copy and paste article from Motor mag with complete history of R32 GTR development and racing history here)
