r33 4 door 93 model
now prefers to spin up one wheel rather than push the car sideways under power through corners
seemed to happen round the time i got exhaust/dump pipe/upped the boost
any easy way to tell how my diff is travelling?
https://www.sau.com.au/forums/topic/56615-is-my-diff-had-it/
"is my diff had it?" - Thats the best english i have ever seen ;)
ummm.....yeh if your diff is single spinning is on the way out....but it wont die....
you will probably find you can lock both wheels if you turn 1 way...like left or right.... when you can turn both ways and it still singles.... then you will have to just put up with it....probably cheaper to get a 2nd hand one than a rebuild....
  • 2 months later...
i have the same problem with my diff, single spinning and also a real pain is the clunking from the drivetrain ( i wont say diff because it appears to be coming from around the rear of the gearbox) Like backlash in the tail shaft. Could it be uni's?
I assume backlash in the diff because it has lost LSD action.
In a zoom or HPI there is a LSD viscous diff rebuild with two spacers instead of 1 to improve LSD lock up. Does anyone know of where this can be done and how much, in melb?
Cheers.
