Sometimes when you watch the odometer tick over, it looks like it's jammed then quickly flicks over.
Bushes are the best indication cause dodgy people don't change them, mainly the obvious like gearknobs, steering wheels and pedals with aftermarket stuff.
https://www.sau.com.au/forums/topic/5663-wound-back-od-meter/#findComment-85599
Well if it stops on the next thousand/10 thousand.. It usually means its been played with :P
We've had this happen to ours. One time it just stopped and didn't move for 400k's. So we took it to the mechanic and he fixed it and said it has been wound back a fair way. Every now and then it stops.. then it starts again :P
https://www.sau.com.au/forums/topic/5663-wound-back-od-meter/#findComment-85774
Clock winding is way too common. The drivers seat is a good indication as mentioned. Also the steering wheel and the gear knob, as they wear the most.
Ive seen TOO MANY imports with completely worn steering wheels and gear knobs, very worn trim etc, only to see 50 or 60 grand on the odo- and the dealers seriously expect us to believe they are genuine k's! Maybe they believe it themselves.. A car with 50,000 genuine ks should be practically new. This is considering many imports with 90,000 ks can still clean up pretty damn well.
Its a worry. Or you get a car in seemingly near new condition, that has a noisy timing belt indicating 100,000!!
Bottom line is too many dodgy operators. Apparently it happens in Japan, and not by people here when they land.
https://www.sau.com.au/forums/topic/5663-wound-back-od-meter/#findComment-85801
Originally posted by zerorespect
it's always buggered me why every1 (nissan, honda, toyota, etc)hasn't gone to digital odometers - maybe controlled by a box marked with the chassis/vin number of the car to hamper swap overs...
Its so they can send them over here and make some $$ :)
https://www.sau.com.au/forums/topic/5663-wound-back-od-meter/#findComment-86208
Mine's 93 with only 32,000km on the clock when I bought it... some of the numbers are not aligned which maybe coz it's been wound back prob in Japan or somewhere here. But all the interior trim, steering wheel, etc etc are in immaculate condition, so could it be that cars with original km still have numbers on the odo misaligned as well? The odo is runnin smoothly none of the above probs happen so far. I haven't check the suspension bushes thou, not sure how to look at them.
But I travelled a lot... 7 months ownership & now I've travelled 9000km in it....
https://www.sau.com.au/forums/topic/5663-wound-back-od-meter/#findComment-86677
Mine was basically the same.. had 33000km on the clock and
everything was still sweet.. but definately the clocks been
played with cause I've had to change my clutch after 11000km..
But these engines are so robust... I've done 30,000 in 10 months
and this thing is a weekend driver...
https://www.sau.com.au/forums/topic/5663-wound-back-od-meter/#findComment-86836
It happens to so most imports i'd say... mate bought a 96 GTS25t skyline in immaculate condition.. showed 11,000km on the clock, seemed close to it aswell. His clutch died completely within a week of driving the car normally. We later saw the exact car on prestigemotorsport website after it was imported (with perth plates on it, rego sticker), saying 52000km. It was owned and driven around in perth for a while then sold to a dealer who my friend bought it off, so it would have been wound back here. No way a clutch on a totally dead stock r33 is going to fry itself to nothing within 11,000km of its life, unless it has been thrashed mighty hard since new, but since the car was stock you would doubt it.
https://www.sau.com.au/forums/topic/5663-wound-back-od-meter/#findComment-86862
    • Purchased a NC MX5 a while ago Basic suspension mods done, BC coils and Whiteline sway bars  New DBA calipers, discs and pads Added some 17 x 8 Konig Decagrams with PS5's Added some typical NA bolt on's, i.e. full exhaust and intake  Added 0.5ltrs with a MZR2.5 swap, nice bump in torques  Found a detachable hard top which is locked in for a colour match with my local paint shop in Feb 25 The little thing is awesome, I drive it everywhere, it handles like a dream whether I'm up it or just cruising  But now,  because I'm a idiot, I keep looking at turbo kits....... did I mention I'm a idiot Why is dose so appealing
    • I would not be surprised if you are the only person on earth that has the interest/desire to do that lol.  The Haltech base map is a really good starting point, the car will fire easily and drive very well, even on mild boost levels. To me, following your advice sounds like some sort of ancient Chinese water torcher lol (this is not an insult Josh, never change <3)
    • Those car show concepts from the 2000's and 2010's like the Floria and IDx were brilliant and should've gone ahead, at least one of them. But neither Honda nor Nissan are thinking about affordable performance any more, which is truly sad.  Even if Toyota's liquid hydrogen ICE development reaches the point where it's commercially viable and the infrastructure to support it, Honda/Nissan would have to wait until Toyota allow fee access to their patents to offer it with any smaller performance models they released to take advantage of it.
    • A sporty manual RWD coupe with a IL4 Honda engine would only be a good thing I assume we won't see anything released for a few years though, unless informal talks and designs have been going on for a few years,  and due to the current, and future, emmisions and safety requirements, I assume anything "sporty" they would do would be at least some hybrid thingie And hopefully anything they are thinking of has nice lines, without lots of plastic and fake bits hanging off it like that horrendous FK8 that looked like it was designed by a 13 year old The other issue of course in the current market is cost, currently the type R is around $70k, a twin is around $50k Meh, I'm old and grumpy and would rather buy a older model car and waste my coin on that than buying anything currently available new
    • Nissan needs to forget about building SUVs in every size possible and bring back the damn Silvia/200sx duo to compete with the 86/brz. Maybe with the Honda type r motor pointing the right way
